BB and Headset Faci...
[Closed] BB and Headset Facing
 Haze
[#4060289]
After powder coating...how important?
Posted : 12/06/2012 12:06 pm
For bike shop owners offering facing as a service, it can be an important source of income.
For everyone else, it's irrelevant.
Posted : 12/06/2012 12:11 pm
 Haze
So not critical, but check the finish and apply common sense?
Posted : 12/06/2012 12:20 pm
Headset facing reasonably important, less so with cartridge headsets. BB facing I've never seen the point to.
Posted : 12/06/2012 12:21 pm
 Haze
I can see the importance of it theoretically, but thought I'd get some actual advice before I part with £30 to get it doen.
Ta!
Posted : 12/06/2012 12:27 pm
Don't do it.
That gives you the opportunity to come on here later whinging about how your BB bearings failed.
Posted : 12/06/2012 12:33 pm
was it faced before you had it powder coated?
If it was then some wet and dry on a block of wood and take just the powdercoat off on the bb/headtube faces prior to refittign the bits?
Posted : 12/06/2012 12:35 pm
 Haze
Erm it was new when I had it, headset cups came fitted and I never faced the BB or anything as I assumed it would already be square from the factory?
Bearings are 4 years old and still running fine so I guess they're seated pretty well.
Posted : 12/06/2012 12:43 pm
I'd just rub the powdercoat down and refit then.
bit of grease on the surfaces and it'll be fine.
Posted : 12/06/2012 12:44 pm
Might be a few globs on the disc mounts which will need removing n'all. Unless its a road bike.
Posted : 12/06/2012 12:45 pm
 Haze
Alex, it's for my Simple - hadn't considered the mounts.
Cheers all 🙂
Posted : 12/06/2012 1:00 pm
