'Battleaxe Two...
[Closed] 'Battleaxe Two chains but no chain slap' bike
 2bit
[#6047049]
Not sure if this has been spotted yet
http://www.gizmag.com/cycle-monkey-chain-slap-drive-train/31252/
Crikey hadn't realise chain slap was such a major issue
Posted : 18/03/2014 9:54 pm
It's not a looker, is it.
I'm pretty sure a clutch mech would be a far lighter, cheaper and better looking solution.
Posted : 18/03/2014 9:57 pm
Pinky, it is available in grey, you know.
Posted : 18/03/2014 10:02 pm
Posted : 19/03/2014 12:15 pm
Since they're using a rohloff hub, they could simply use a rohloff chain tensioner.
But that's not the ethos with nahbs bikes...
Posted : 19/03/2014 12:18 pm
They've eliminated the noise of chain slap by using a Rohloff?
What about the constant "pepper mill" noise coming from the Rohloff?
Or the fact the Rohloff constantly leaks oil on to the disc? Is the non-squealing brake rotors a "designed in feature" or is that a happy accident?
Posted : 19/03/2014 12:57 pm
no chain noise is the least interesting bit on that. little or no pedal feedback / chain influence on a high pivot is a quite desirable trait in some circles.
Posted : 19/03/2014 1:42 pm
Er, no it doesn't. Not unless you've got an old Rohloff that needs new oil seals, a 10-minute job to sort.
Posted : 19/03/2014 1:45 pm
 hels
You don't get chain slap if you ride everywhere in a huge gear. Grrrrrrr.
Posted : 19/03/2014 2:08 pm
 LoCo
Lot of effort to put Roloff in as rear hub, why they didn't mount it inboard, centrize mass and reduce unspung mass I'm not sure 😉
Posted : 19/03/2014 2:18 pm
looks like one of those Brooklyn Machine Works overly complicated DH and hucking machines
hub gear makes it (marginally) more sensible
Posted : 19/03/2014 2:21 pm
Lot of effort to Roloff in as rear hub, why they didn't muount it inboard and centrize mass and reduce unspung mass I'm not sure
Yeah this makes no sense - Mount the Alfine where the pivot is if your building the frame from scratch. And if your doing that use a pinion gearbox instead. Both have been done before.
I don't see how this is any improvement on a BB pivot bike
Posted : 19/03/2014 2:30 pm
 LoCo
Think an inboard Rohloff would be more reliable than a Pinion from what I seen of them although 'packaging maybe a bit more of an issue
Posted : 19/03/2014 3:17 pm
