Bash gaurds?
[Closed] Bash gaurds?
I know loads of you will say they are not needed but.... When going to order one, there are loads of sizes available. Would i be right in saying you order the same size as the amount of teeth on the middle ring?
Posted : 10/12/2009 6:43 pm
If you order one with less teeth it won't do anything. If you order one with more teeth than your current ring you will have less ground clearance, but scope to increase the size of your ring without having to buy a new bash. I think. Same is good. More is quite good but don't go crazy. ๐Ÿ™‚
Posted : 10/12/2009 6:46 pm
 jedi
i still use a triple and tooth fairy bash guard on the hummer
Posted : 10/12/2009 6:53 pm
Thanks for the reply's, slightly bigger it is then!
Posted : 11/12/2009 7:14 pm
Got to say, I'm very interested in one of these;
Unless I go Hammerschmidt on it. Hmmm....
Posted : 11/12/2009 7:17 pm
 jedi
i liked the hammerschidt
Posted : 11/12/2009 7:19 pm
That's clever, that Raceface thing. Still would be better to just take off the big ring mind.
Posted : 11/12/2009 8:02 pm
Unless of course, much of your riding needed a big ring, in which case, that RaceFace thing is an ideal solution!
Posted : 11/12/2009 8:03 pm
get a 36t middle and mtfu
Posted : 11/12/2009 8:50 pm
