Bars - flat or rise...
[Closed] Bars - flat or riser?
Just not sure.
Need to go shorter and wider on the Patriot.. maybe lower too I don't know. I could run the bars lower and then wind the forks all the way out too to get slacker angles.. hmm...
Posted : 09/03/2015 10:31 am
i'm increasingly moving towards flat bars, if for no other reason than it makes them easier to adjust.
i'll try and explain; with riser bars, the back sweep is 'on top' of the rise, if you rotate the bars to tweak the back-sweep up or down a bit, you also effectively lengthen/shorten the stem.
it's not a huge problem i admit, but i've got a shonky wrist or 2, and am finding it tricky to get comfy, so have become a bit obsessed with bar-adjustment.
(also, wide flat bars look great)
((also, flat bars give you more room for stuff like lights, speedo's, bells, etc))
Posted : 09/03/2015 10:40 am
With the 5deg stem I have now I've slammed it and kept 4 spacers, so there's plenty of room to raise it again if I have a flat bar.
Do they both come with similar sweeps?
Posted : 09/03/2015 10:46 am
i think so...
my new favourite bars are Ritchey trail x2 (i think), 740mm wide, 9 degree sweep, 280g, £25 or so.
but i've seen similar with sweep ranging from 3 to 12degrees (3T extendo)
Posted : 09/03/2015 10:47 am
