bar tape
[Closed] bar tape
[#5508279]
Can someone recommend me some bar tape.
Need something that will help eleviates some pressure on the palms.
Was looking at the zipp zervice course, fizik stuff or lizard skins dsp?
Posted : 11/09/2013 8:39 pm
Lizard Skin all the way.
Posted : 11/09/2013 8:45 pm
If you've got pressure on your palms to the extent that you need to alleviate it, your position needs looking at before your bar tape.
Posted : 11/09/2013 8:48 pm
Specialized Roubaix tape v comfy...
Posted : 11/09/2013 8:49 pm
 Haze
The Zipp stuff is very comfy, normally go for the Fizik Microtex but couldn't find stock at the time.
Have Deda on my fixed which is pretty good too.
e2a...maybe drop your saddle a touch also?
Posted : 11/09/2013 8:51 pm
+1 Specialized Roubaix
Position is currently being worked on as is setup.
But just looking as to setup properly I may need to move the hoods 8n the bars, so figured I could replace the tape at the same time.
Posted : 11/09/2013 8:55 pm
Bontrager do a double gel one, very comfy.
Posted : 11/09/2013 9:19 pm
I think of bar tape as an essentially consumable thing, so I buy relatively cheap stuff and change it every few months.
Posted : 11/09/2013 9:24 pm
Specialized S-Wrap cork is my favourite tape to use. Comfy and grippy.
Posted : 11/09/2013 9:35 pm
dsp +1, expensive, but worth it
Posted : 11/09/2013 9:39 pm
I think the dsp now comes in an extra comfy 3.2mm.
Posted : 11/09/2013 9:42 pm
ESI bar tape is awesome.
Posted : 11/09/2013 9:59 pm
Just double layer it, like the pros do when they ride cobbled races like Roubaix or Flanders
Posted : 11/09/2013 10:24 pm
I like the Cinelli Tennis Bar Tape 😀
Posted : 11/09/2013 10:25 pm
Specialized Phat has a gel layer underneath. Pig to put on but very comfy.
Check your position too.
Posted : 11/09/2013 10:46 pm
I knew esi were developing a bar tape but i didn't realise it was out to retail?, i'll away and google......
Otherwise Lizard skins esp as others have mentioned - it's pretty damn good and easy to fit/wrap.
Posted : 11/09/2013 10:49 pm
Zipp cyclocross tape is the thicker lizard skins stuff (except it has zipp written on it)
Posted : 11/09/2013 11:10 pm
Mr smith forgive me but how come its halfthe price?
Posted : 12/09/2013 6:08 pm
I shall unrecommend Fizik, very "ridgy", you can really feel the edges of the tape where it overlaps. Nice otherwise.
Posted : 12/09/2013 6:23 pm
Easton cork is not bad for £8 . narrow glue strip so re-positioning is easy. Seems very comfy and as good as the Roubaix tape I had before . Cannot comment on its long term niceness as its only done 200 miles so far.
Posted : 12/09/2013 8:21 pm
I usually use fizik microtex stuff on all my road bikes but went for ritchey stuff for a change on one of my commuters as I have ritchey bars/stem/post/headset/fork on that bike so continued the collar and cuffs theme ( to the max
Posted : 12/09/2013 8:56 pm
I usually use fizik microtex stuff on all my road bikes but went for ritchey stuff for a change on one of my commuters as I have ritchey bars/stem/post/headset/fork on that bike so continued the collar and cuffs theme ( to the max :)). It's very nice, comfy if that's your bag and I'm very pleased with it.
Posted : 12/09/2013 8:57 pm
