Avid Juicy question
[Closed] Avid Juicy question
Is a 160mm identical to a 180mm except for the rotor? What's the difference?
Theres a deal on a 160mm front which I want to replace my 180mm with, don't know if I can?
Posted : 13/06/2009 9:01 am
You'll also need one of these in the relevant size.
[i]i.e.[/i] a 160mm mounting bracket in place of the 180mm you currently have.
[url] http://www.wiggle.co.uk/p/cycle/7/Avid_Caliper_Mounting_Bracket/5360016421/ [/url]
A request on the STW Classifieds might get you a cheap one.
Posted : 13/06/2009 9:12 am
So the brakes are different, I can't put one advertised as 160mm on a 180mm mount to fit my 180 rotor?
Posted : 13/06/2009 9:26 am
u need a different mounting...the actual caliper is identicle
I'm being really stupid, why can't I use the existing 180 Juicy mounting bracket?
Posted : 13/06/2009 10:17 am
[b]you can[/b] The ONLY differences in sizes are the rotors and the bracket you use EVERYTHING else the same buy it attach to your mount ride away.
Posted : 13/06/2009 10:23 am
Is that yes or no?
๐Ÿ˜€
cheers
Posted : 13/06/2009 10:28 am
enfht - Member
No the brakes are the same. Yes you can put the advertised caliper on a 180mm mount and use with a 180mm disk.
The calipers are common, you change disk and matching mount to vary the sizes.
Clear? And yes, you are being stupid ๐Ÿ˜›
Posted : 13/06/2009 10:32 am
YES they are the same calipers are just to a set standard (post mount mainly these days) and we alter mounts to fit the rotors we choose with 160 post mount having no bracket (FRONT)
Rears are all IS standard so always require an IS to Post adapter os whatever size
IS mounts are 20 mmm smaller at the rear than front so a front 180 is a rear 160
Any questions?
Yes you the confused looking one at the back ๐Ÿ˜†
Posted : 13/06/2009 10:33 am
So it's a NO then
cheers ๐Ÿ˜‰
Posted : 13/06/2009 10:44 am
