Avid bleed kits (ch...
[Closed] Avid bleed kits (cheaper ones...)
Hi all,
New to the forum so hello to you all. Hoping you can help. My mate recommended I get an aftermarket bleed kit as he bought one off Ebay from Cyclonix. I have seen their website - www.bleedkits.co.uk
Anyone had any dealings with Cyclonix?
Thanks in advance!
Posted : 04/06/2012 7:02 pm
 Taff
I've not bought them but the Cyclonix ones were the ones that were recomomended to me before.
Posted : 04/06/2012 7:06 pm
 Taff
ONly thing I would question is that there are syrninges using dot5.1 fluid. I'm pretty sure that dot5.1 makes the syringe rubber expand to the point where the syringe will no longer work.
Posted : 04/06/2012 7:08 pm
Be careful what ones you buy. I got one from a seller and the brass fitting wasnt long enough and the shoulder hit a caliper body bolt and wouldn't screw into it. Got another set from epicbleedsolutions on the bay and they were perfect.
Posted : 04/06/2012 11:12 pm
 pdw
Should be fine.
As above, the only tricky thing with Avid brakes is that the bleed screws are recessed, so many brass fittings won't screw in properly. Looking at the photos, those Cyclonix ones should be fine.
Posted : 04/06/2012 11:24 pm
try red dog racing 😛
Posted : 05/06/2012 9:29 am
I used the Cyclonix one from www.bleedkits.co.uk and it was spot on!
Posted : 07/06/2012 2:11 pm
+1 for red dog racing. £15 IIRC
Posted : 07/06/2012 2:14 pm
Looks like 'leejinxuk' and 'jenko73' are the same person. Look at their profiles. Lee Jenkins owns bleedkits.co.uk by the look of things. Why are you posting as someone else about your own site? Not cool. hah.
Posted : 04/07/2012 9:09 pm
BUSTED!
Posted : 04/07/2012 9:16 pm
Powned!
To be fair the OP stands out a mile off as astroturfing.
Posted : 04/07/2012 9:23 pm
Posted : 04/07/2012 9:24 pm
The cheapest ones on ebay are the doctor coopers.
Mind; none of these come with sealed dot 5.1
Posted : 04/07/2012 11:02 pm
Hah, behold the shaft.
I use Epic bleed kits, they look very similiar to Cyclonix so who knows, that might be leejinxuk too. But they do the job anyway.
Posted : 04/07/2012 11:06 pm
downhillpete - Member
Well spotted that man. Wow, what a d*ckish thing to do. Suspect it goes on quite a lot unnoticed actually.
Posted : 04/07/2012 11:51 pm
This is quite amusing actually. 🙂 I'd just like to say we are in no way affiliated with Lee Jenkins or bleedkits.co.uk.
Posted : 05/07/2012 7:53 am
Neither is www.DoctorCoopers.com
Posted : 27/07/2012 10:39 pm
I bought one off Ebay for £12, it did the job just fine.
Posted : 27/07/2012 10:41 pm
He he, epicbleedsolutions it is then.
Thanks to leejinx for bringing epicbleedsolutions to my attention.
I will be using them for my bleed kit I think
Posted : 27/07/2012 10:47 pm
