ASR5 or bandit?
[Closed] ASR5 or bandit?
 rock
Hello all,
I'm undecided on which of the above to go for. Bought the build kit, just need to decide on the frame.
I know the bandit's slightly heavier and maybe a little plusher, but what else should I know?
Posted : 26/01/2012 10:53 pm
Not ridden an ASR5, but own a Bandit. Really pleased with it.
The frame isn't the lightest, but a full build still comes in below 30lbs without too much effort (26-27lbs is possible if you really chuck money at it). It's probably not the fastest up or downhill, but it seems to do everything pretty well. And the overall quality of the build and finish is excellent. All in all, couldn't be happier.
That said, the ASR5 is by all accounts a bit of a ripper too. Would it be the alloy or carbon one you'd be looking at? I may be wrong, but I think the carbon one only takes a 120mm fork, whereas the alloy one is good for 140mm (or maybe even 150mm?). Bandit is designed for 140mm/150mm (I have the latter and love how it handles).
As always, probably best to arrange a test ride on both and see what you think!
Posted : 26/01/2012 11:04 pm
 rock
Yep, aiming for the alloy asr5. The large asr5 felt slightly too long for me (i'm 6ft 1), and like quite a big, tall bike. On the other hand, the bandit felt a bit more "right".
Mainly using it for singletrack and long days in the hills, with the odd race. I'm coming from an anthem and looking for something a little more playful, which can handle decent sized drops.
Posted : 26/01/2012 11:13 pm
I'd go for a Bandit, they seem to suit the riding I do and they look better IMO. Singletrack reviewed it [url= http://singletrackworld.com/reviews/?p=5180 ]here[/url]
Posted : 26/01/2012 11:17 pm
Well if the Bandit felt "right" then go for it! Transition frames are designed for more aggressive riding so you should be fine. That said, if you're looking for something to handle lots of decent-sized drops, have you tried a Covert?
Posted : 26/01/2012 11:28 pm
ARSE Bandit?
just me? me?
ok ...
Posted : 26/01/2012 11:29 pm
ARSE Bandit?
๐Ÿ˜†
Posted : 26/01/2012 11:44 pm
