Arrrrrrgh.... Ive c...
[Closed] Arrrrrrgh.... Ive cut my steerer too short.. help please.
[#6139583]
Just to distract from missing frame deliveries Ive gone and done it.
Cant believe i managed that one... brand new carbon forks.
Distracted by kids, the dog and a shitty headache ive ballsed up my steerer cut.
It might just be savable with...
A low stack headset cover.. (Ive got an integrated FSA headset 41.8 upper)measures 16mm in stack height.
A single bolt low height stem such as the truvativ XR 3D.. the one ive got is 41mm.
I need about 17mm to save it... whats the lowest headset cover i can get ?
Help me please.
I dont have any other options as i cant get replacement forks.
Posted : 24/04/2014 4:11 pm
17mm!?
Sorry to hear that but that might be ambitious
What frame and forks is it?
Posted : 24/04/2014 4:12 pm
Tell me this ain't the Tripster!
Anyway, can you lose a few spacers? Or did you [i]really[/i] do yourself a mischief?
Posted : 24/04/2014 4:13 pm
Syntace Flatforce stem?
Otherwise, can you get an new CSU?
How long a stem are you using? If it's short, the 50mm Tioga/bikehut ones are really low stack and might work.
[i]can you get an new CSU[/i]
I assume they're rigid forks?
Posted : 24/04/2014 4:14 pm
Jamie - Member
Yup.
Posted : 24/04/2014 4:15 pm
17mm is a lot to lose,
A stem may lose you 7mm going to a 35mm one. Headset top cap may lose you 5mm, so you are stumped if you have no spacers to remove.
Posted : 24/04/2014 4:19 pm
Need a stem with stack lower than 41mm.
Need a headset cover lower than 16mm.
do smaller frame sized tripsters have a shorter headtube?
Can you find someone with a smaller frame and uncut steerer to swap with?
Posted : 24/04/2014 4:20 pm
 IA
One of these fit?
http://metallicpoutine.com/shop/headset-bearing-cover-caad10/
Posted : 24/04/2014 4:22 pm
Can probably get away with 15mm..
It is the smallest size 48cm frame so no swapsies.
There are no replacement tripster forks.
Posted : 24/04/2014 4:25 pm
Looks like one of these in worst case scenario:
http://www.wiggle.co.uk/bbb-bhp-2021-stem-extender/?lang=en&curr=GBP&dest=1&utm_source=pla&utm_medium=base&utm_campaign=uk&kpid=5360445133
If it it an alu steerer...
Posted : 24/04/2014 4:30 pm
You know the steerer doesn't have to quite come up to the top of the stem, don't you?
Posted : 24/04/2014 4:32 pm
Yes.
I know its savable with lower stack stuff.. just dont know where to find them.
Carbon. Brand new carbon forks. To fit the mother of beautiful Ti bikes. It will just be a little lower at the front than i had maybe planned.
Posted : 24/04/2014 4:36 pm
The old spank spike stems had super low stack height: http://www.vitalmtb.com/product/guide/Stems,39/Spank/Spike-Stem,7027#product-specs
Ps just sent you an email about saddle
Posted : 24/04/2014 4:37 pm
26mm!
Thanks everyone for the suggestions. It was a complete non-brain engaged moment of forgetting to add on the height of the stem when i had a pen in my hand ready to cut. I momentarily nearly cried.
Posted : 24/04/2014 4:40 pm
Rollo.. its for a CX / Road bike / do it all bike.. the spank may not work looks wise
Posted : 24/04/2014 4:43 pm
Your forks don't work ANY wise currently... who cares about looks when you're throwing carbon forks in the bin ?
Just buy some new forks. Plenty of full carbon monocoque disk forks around.
Posted : 24/04/2014 5:01 pm
Odyssey do a quite low-stack integrated headset:
I suppose you could you consider a BMX stem to go with it like this:
22.2mm bars might be an issue...
How about a DMR "Defy Stem:
31mm stack height apparently...
Posted : 24/04/2014 5:11 pm
Just looking for a cheaper option.. it was quite a special purchase followed by a very special mistake
Posted : 24/04/2014 5:12 pm
Ah sorry just realised this is for a tripster so I doubt you want a 50mm DH stem, how about a Thompson X2 - 36mm stack height...
Posted : 24/04/2014 5:17 pm
Give Kinesis a shout? Normally quite helpful, and might be able to suggest something?
http://www.kinesisbikes.co.uk/contact/sales/
If it's any help, i've skimmed a similar type of headset cover down to 5mm depth on a lathe, should open up the choice of stems you can use.
Posted : 24/04/2014 5:24 pm
If it in anyway eases your pain, I ruined my rear shock at the weekend, distracted set my torque wrench to ftlb instead of inch.
Posted : 24/04/2014 5:25 pm
Slam that stem bearing cover.
need to buy via a dealer though.
Planet X /On oNe CNC stem has a stack of 35mm.
http://www.on-one.co.uk/i/q/STOOCNC/on-one-ultralight-cnc-stem
I believe superstar have the same stem
Posted : 24/04/2014 5:37 pm
Ragley Stubbing stem has a low stack height (30mm)
Posted : 24/04/2014 5:44 pm
Is it the standard tripster fork, what length steerer do you need?
Posted : 24/04/2014 6:47 pm
Do you have the offcut? Can you get an aluminium insert bonded in and stick a bit back on?
Posted : 24/04/2014 7:15 pm
If it's a carbon steerer, it should always be slightly proud of the stem with a spacer above it, to spears the load out over as much area as possible.....
Posted : 24/04/2014 7:23 pm
wouldn't one of those steerer expanders be fine for a road/cx bike? Works in exactly the same way as an old quill stem that people use to use back in the day. Cost you about a tenner.
Would this 5mm top bearing cover do the trick??
http://www.cannondalespares.com/Cannondale-Road-Headset-5mm-Top-Bearing-Cover,-KP253/product_detail/3-40270
Which would give me 11mm and just need a lower stack stem of about 35/36mm.. which gives me more options on a stem
Posted : 24/04/2014 10:24 pm
Give Matt at Upgrade bikes a call and ask him if they have any spare Tripster forks lying about.
Posted : 24/04/2014 10:26 pm
This is the response i had from upgrade earlier today... We actually do not even have enough forks for the amount of frames we have here at present, we are currently running behind with the factory production. So unfortunately, bad news, we cannot help with a replacement fork. We simply cannot get enough of these framesets, let along the forks on their own.
Posted : 24/04/2014 10:30 pm
I would get someone to turn a a stepped plug for the top of the fork
Extends 3 inches inside with a slight taper to it, glue it in on the brightside you could included the thread for the topcap in the job
Posted : 24/04/2014 10:34 pm
Anyone familiar with AX ligthness??
I have that cap on the far right..
They make the cap on the left which is what i want..
[URL= http://i219.photobucket.com/albums/cc310/jenga101/whdx_zps93fc81a7.jp g" target="_blank">http://i219.photobucket.com/albums/cc310/jenga101/whdx_zps93fc81a7.jp g"/> [/IMG][/URL]
Posted : 24/04/2014 10:36 pm
Ahh bugger, thats a shame. I'm not surprised regarding the frames selling out as fast as they can make them as when i was up at aviemore last week i got talking to a few folk i met by chance when out and about, i allowed them to borrow my Tripster ATR for a couple of hours each ( i got to borrow a nice carbon Colnago and a specialised roubaix) and when they came back they were without a doubt in their minds decided on buying one.
Posted : 24/04/2014 10:39 pm
Just view it as the Gods way of saying "buy an Enve CX Disc fork". Or even a Whiskey a Products 15mm TA CX Disc Fork...
Posted : 24/04/2014 10:41 pm
Early Xmas prezzie 8)
[url= http://whiskyparts.co/catalog/forks ]Whiskey #9.[/url]
Posted : 24/04/2014 10:44 pm
Just to go back to what Peter was saying, if you get the 17mm will that allow the stem to properly clamp the steerer? just being full carbon, you need to do this things right to reduce the risk of things going bang.
P.S: Stupid 15min edit window.
Posted : 24/04/2014 10:59 pm
