Argh! Stuck axle (P...
[Closed] Argh! Stuck axle (Pro 2 content)
[#7122759]
After a bent QR dropout on my Voltage I decided to upgrade to 12mm thru axle - but has turned into a major operation having to order new dropouts from France, a thru axle and an axle conversion kit for my hope pro 2 hub.
I've got the freehub off but can't get the axle out. Seems to be stuck solid.
I've tried from both sides and it doesn't seem to move. Using a support for the hub and a rubber hammer.
Anyone got any tips on how to remove it? I could take it into my LBS but I can't imagine they'll do anything I can't do. Unless it requires special tools.
Posted : 10/06/2015 8:53 pm
Needs a coarse grade hammer- pro 2 doesn't have any special tools. Cap off first if you haven't already just to have as few parts as possible (it'll tap out easily with a poky thing through the axle) and the axle will exit in either direction, it's literally just held in by the bearings.
Posted : 10/06/2015 8:58 pm
Poky thing being something like a screwdriver?
Posted : 10/06/2015 9:00 pm
Hit from Freehub side so it comes out on the Non Drive. Like OP says. Only held in by beaings. Hit it harder!
Posted : 10/06/2015 9:02 pm
Any risk of damage?
Posted : 10/06/2015 9:10 pm
Not particularly.
The axle has got to come out some way.
Just make sure you hit it straight and not at an angle.
Posted : 10/06/2015 9:19 pm
Only if you miss with the hammer...
Put something on the end of the axle as they're quite soft.
The shock absorbing hammer won't be helping!
Posted : 10/06/2015 9:52 pm
I had the same and it's the inner surface of the bearing seized onto the axle.
Bigger hammer and more spray lube.
It took a few days of spraying and hitting. Then it slid out easiy.
Posted : 11/06/2015 8:03 am
Made a better support for it out of wood and whacked it from the Drive side - came out first time.
Cheers for the advice!
Posted : 12/06/2015 5:52 pm
