Are steep seat angl...
[Closed] Are steep seat angles spoiling hardtails?
I've read a few posts on this forum and others about the unforgiving nature of hardtail bikes recently and I can't help thinking when I look at a lot of modern hard tails that the current fashion for steep seat tubes and also to lesser extent, short chain stays is going to stuck a lot of compliance out of the frame and this is probably why a lot of people just can't get on with them?
Posted : 20/12/2019 8:53 am
The average age of the forum is about 50. We’re all knackered 😀
Posted : 20/12/2019 8:58 am
No. It's because people are soft and they can't ride properly - HTH! 😉
A bit more seriously, I think it's just a bit of a shock moving over to a HT after a bit of time on a FS, even just a few weeks on a FS can have me thinking 'hell's teeth, this is rock hard!' when I inevitably move back to a HT.
Posted : 20/12/2019 8:59 am
Depends....
on what you want from it, super steep seat angles will suit super steep climbing, but not so just riding along the undulations.
Frame compliance is not just geometry angles and measurements, you also need to factor in material type (Ti, steel, aluminium, carbon, bamboo), tube diameter, thickness, butting etc
So many variables.
On frame geometry, I read somewhere: "if you improve one characteristic (by adjusting angles, measurements etc), you'll make another worse. At the end of the day, it's a compromise".
Oh, and define "steep" someone like Chris Porter may have a different idea on that than you or I.
Posted : 20/12/2019 9:01 am
Yes.
For me on my local terrain anyway, which I realise might count for nothing compared to the riding others do.
But not for the compliance reasons. Steep (75-76 or more static) STAs are great for changing/correcting weight distribution for longer front-centre bikes and for better climbing, but combined with almost all posts being inline, they aren't as good for longer, rolling terrain riding - and that's where I really like hardtails. The weight-fwd over the BB + bar feeling simply isn't as comfortable if you're spending more time seated, can lead to back or shoulder tensions etc. I used to really like one of my old hardtails for it's slacker ST and sat-on-back-wheel feel, it popped wheelies or could go light at the front or hop so naturally - was much more playful than a LLS HT. Had to climb steep stuff stood up but that's OK imo.
Hardtails are also great for just ragging around the local woods for a bit and tbh there I'd still prefer a slightly less long-slack set up, like 'just slack enough' big 4X bike rather than 'how slack do we need to be to get noticed' sort of FS-copy geometry.
I do think 2 degrees on STA can change comfort for the high-posters, via seat post flex, but so does seat post spec and simply how much is exposed. I had a road-ish bike made a while back with a 71.5 STA to use with an inline post with the same ST size as normal, for that reason. Hard to say how much benefit there was but as one of those things that can add up with other factors it seemed to help.
Posted : 20/12/2019 9:14 am
What jameso said!
Posted : 20/12/2019 9:19 am
I don't think that many HTs have proper steep STAs yet, so I'm gonna say "not really".
If the reach extends at the same time, it all comes together anyway - only snag might be when the bike gets too long & slack to be as much fun on flat, twisty trails.
Posted : 20/12/2019 9:22 am
Seat tubes are basically incompressible, and chain stays would have to bow out massively to give the compliance that a tyre does. IIRC a while back Brant explained that the compliance of a frame basically comes from flexing of the top tube. Seat angle won't make any perceptible difference. A long, flexy seat post will, as will a fatter tyre run at lower pressure.
It seems to get forgotten that hardtails get steeper once you’re on them whilst full-sus bikes get slacker, and even more so when pointed uphill.
And on most hardtails the effective seat tube angle is much closer to or the same as the actual seat tube angle, so they don’t get slacker as you raise your seat as with pretty much all full-sus bikes.
A 74 deg seat tube angle on a hardtail could feel as steep as 77 deg or more on a full-sus.
This. I think it depends a lot on how and where you ride. Most of my local Peak stuff seems to be either up or down, and relatively steeply at that. Statistically you probably spend more time climbing than descending. And when you're descending, you're out of the saddle anyway. And I like steep tech climbs.
Personally I hate the nasty wandering, front end light, and oops, now it's off the ground feel of slacker seat-tubed bikes on steep stuff, but as above, that's me on my local terrain anyway, which I realise might count for nothing compared to the riding others do.
Posted : 20/12/2019 9:29 am
Bikes are becoming more extreme and many riders don't ride terrain anywhere near tough enough for the new hardcore hardtails that riders think they need when in actual fact they'd be better off on some sort of flat bar gravel bike.
Posted : 20/12/2019 9:32 am
brant +1!
most riders are massively overbiked (me included)
i love a good HT though. my full suss barely gets ridden locally. I`ve not noticed a steeper seat tube being detrimenatal.
my new longer framed HT is definitely less engaging to ride than my old one. it`d be great at BPW but for my local South Downs stuff a smaller frame is more fun as the trails are just too tame for a long stable bike.
Posted : 20/12/2019 9:44 am
Plus the aesthetics issue! A slack head tube and steep seat tube does not make for a pretty bike.
Posted : 20/12/2019 9:52 am
I only ride my ht in the winter but knew my back was going to suffer so fitted it with the cheap Suntour Thudbuster clone almost straight from the off.
Im genuinely surprised at how much comfort it adds. Not bothered about the weight as it's covered in mud anyway.
Nothing to do with a steep seat angle but still...
 Bez
Bikes are becoming more extreme and many riders don’t ride terrain anywhere near tough enough for the new hardcore hardtails that riders think they need when in actual fact they’d be better off on some sort of flat bar gravel bike.
https://singletrackworld.com/forum/topic/controversial-cycling-opinions-lets-hear-em/
Posted : 20/12/2019 10:04 am
Which bikes do you have in mind when you say this? I've not seen any hardtails with super steep seat angle.
Posted : 20/12/2019 10:29 am
If you think about it, since wheel sizes increased, stays will have become longer anyhow; steepening the seat angle allows shorter stays, bringing back the glory days of fun, snappy and agile 26ers!!
When it comes to compliance, ride feel can be engineered in; think back to the 456 Ti with the curved top tube, or Production Privee's shaped stays...
Whether or not that's entirely necessary, given the additional flex likely to result from the increased reach and longer tubes of modern geometry, is another matter
Posted : 20/12/2019 10:43 am
I've just ordered an Orbea Laufey - 65 HA, 75 SA 140 mm travel. My 90s Klein had a seat angle of 73.2 degrees. A 2020 Spesh Fuse is 74. A Cotic Soul is 73 degrees.
Posted : 20/12/2019 10:44 am
I remember when pretty much all bike were XC oriented. Even when sus forks were considered too heavy, so kind of agree here. Although I think some suspension is nice to have.
Posted : 20/12/2019 11:08 am
Agree with much of the above. My Sherpa has a pretty slack seat angle by the current trend but the whole geometry of the bike seems to suit me fine. No issues on steep climbs, technique is more important.
Posted : 20/12/2019 11:12 am
I'll be finding out soon, going to a LLS bike, 3 degrees more HA and 2.5 degrees steeper SA than I have currently. No idea how it'll be but keeping an open mind. It'll be mainly used on rolling terrain similar to that described by jameso.
I quite like the idea of LL-NotTooSlack for a modern XC/bit of everything bike, much like the new whippet. Might cover more bases better for less steep terrain.
Posted : 20/12/2019 11:29 am
 Bez
I wonder whether a lot of it is just that people who've used full sus for ages have just got used to sitting down.
The best solution is probably for them to go to a rigid singlespeed first, where you basically never sit down, and then dial themselves back to the luxurious plushness of a hardtail 😉
Posted : 20/12/2019 12:19 pm
null
Posted : 20/12/2019 12:32 pm
Hasn't that always been the way though? I date it back to the Whyte 46 when the Peak was suddenly full of slightly overweight middle-aged men pushing up climbs and pottering downhill. The bikes have changed, but the basic pattern is still pretty much the same. A lot of it is undoubtedly attributable to seat-tube angles, but there's possibly more to it than that.
Posted : 20/12/2019 1:07 pm
Used to have a Charge Blender. An absolutely classic steel hardtail that was slightly spoiled by its slack sta. It was a pig to pedal around all day.
My Production Privee is bang on. Like the Blender always could have been.
I don't think they spoil them at all. Always a balance.
Posted : 20/12/2019 1:08 pm
while parallel HT and ST looks nice on a XC focused bike - bi of roadie aesthetics there?
counter argument - when the head angle is steeper than the set tube it looks like its been ridden into the wall and looks ridiculous.
Posted : 20/12/2019 1:21 pm
Another thing making a big difference is dropper posts. These tend to be a lot stiffer than a good lightweight rigid post.
Posted : 20/12/2019 1:41 pm
Most trail hardtails are being specced with fatter tyres and wider rims these days, so not sure how relevant the recent feedback you've been hearing is. As for Brant's comment re: riders being better off less biked, I don't think this isn't anywhere near the general case. A bigger bike may be OTT for the average trail centre, but a decent rider will get the speed out of one and have fun doing it.
Posted : 20/12/2019 2:01 pm
I've said that before - that a nice thompson is much more comfy than a dropper in the up position - and got roundly called an idiot. Good to find someone that agrees with me.
Which kind of brings me to the next point. Back when all hardtails were steep xc machines, people rode them, and rode em on some challenging stuff. Then long and slack came, and people realised they were better for the steep chutes, for the high speed and so on.
But that brought with it a reduction in the long distance XC ability. Those bikes still exist, and at pretty much every price point. For some people/ some rides, they'd be a good choice. From your bimblers to your South downs way in a dayers.
Go over to the likes of a BFe, Zero, Crush; and you've given up that seated pedalling on flat terrain ability. If you like these sort of bikes - which I do now, I've fallen in love with the Zero29 - you need to stand up and crank those pedals hard. I'm riding for a fun time, not a long time.
Posted : 20/12/2019 2:06 pm
I’ve said that before – that a nice thompson is much more comfy than a dropper in the up position – and got roundly called an idiot. Good to find someone that agrees with me.
how many mm are you imagining the rigid seatpost is compressing or flexing by?
Posted : 20/12/2019 2:36 pm
I like my fairly LLS Enduro for certain trails, but on others a more moderately proportioned HT feels nicer.
For example I’m going to Flyup 417 on Sunday. I’ve done it on FS and HT before - with the FS I enjoy the rockier reds more, on the HT the blues rock - just trying to corner harder and harder. For me and my riding I’m not sure a LLS HT would be as fun as a moderately modern one (Vitus Sentier 650b).
Posted : 20/12/2019 2:44 pm
compressing - none
Flexing -
73 degree seat angle, 300mm long, 30.9 seat tube with 2mm wall thickness.
Assuming a veritcal 90kg load thats 26.3kg perpendicular to seat tube.
I get 1.8mm deflection.
50% more for a 27.2mm with 2mm wall thickness
Posted : 20/12/2019 2:59 pm
That deflection is perpendicular to the seat tube? If so, the vertical deflection will be less than 1 mm, if I understand it correctly. Pretty small compared to the deflection in a tyre.
Posted : 20/12/2019 3:18 pm
well yes, but its still a few mm of "give" that will reduce the jolt to the gooch compared to a much stiffer dropper shaft.
Posted : 20/12/2019 3:30 pm
but we're not talking about vertical deflection being the important part, perpendicular deflection (ala the same line of travel as something like a thudbuster) would be more relevent to comfort.
Posted : 20/12/2019 3:31 pm
that said, when riding, the load applied to a seatpost won't be vertical either, the max load will likely be more complicated than that, if you imagine hitting a lump in the trail, there will be a vertical component against your butt, but also a horizontal component to get past the lump. How much of the latter will be determined by how much friction is applied to the saddle from the rider.
Posted : 20/12/2019 3:34 pm
Heres another thought, could a dropper post have a some degree of travel engineered into it. Say 5mm of sag dropping another say for the sake of argument 20mm under full compression? And then have 100mm or whatever dropper capability. I know it probably sounds like the knackered dropper you chucked in the corner of the shed...but I think it sounds like hardtail seat post heaven.
Posted : 20/12/2019 3:46 pm
if you need a suspension seatpost why not just buy a suspension frame as that sounds what you want.
i recon a HT is for standing up on the rough bits.
Posted : 20/12/2019 3:55 pm
BadlyWiredDog
...Personally I hate the nasty wandering, front end light, and oops, now it’s off the ground feel of slacker seat-tubed bikes on steep stuff, ...
That's probably more to do with the larger amount of flop in you get with slack HAs (although seating position plays its part), and why the previous version of "modern trail geometry" of the 1920s fell out of favour.
Posted : 20/12/2019 4:03 pm
markrh - an air dropper with a blow off valve 👍
Posted : 20/12/2019 4:13 pm
It's an acquired taste. I rather like a super-slack head and steep seat tube.
null
Posted : 20/12/2019 4:23 pm
My aging KS Dropzone-R has developed this. Was better when it worked properly TBH 😉
Posted : 20/12/2019 4:35 pm
here you go...
https://www.pnwcomponents.com/collections/shop-all-droppers/products/coast-suspension-dropper-post-external
Posted : 20/12/2019 4:38 pm
brant
Subscriber
Still, it's not like "need" has much to do with anything.
Posted : 20/12/2019 4:53 pm
 Bez
There's already a blow off valve at the top of my seatpost.
Posted : 20/12/2019 4:58 pm
lovewookie, thanks for that link to Coast. WANT!!
Posted : 20/12/2019 5:11 pm
Thanks, I appreciate the actual numbers but in real world terms and effect, compared to the amount of movement in saddle flex, padding clothing, skin and muscle: sweet FA.
Posted : 21/12/2019 9:38 am
They're not "actual" numbers, they're educated guestimates.
Posted : 21/12/2019 3:37 pm
No worries.
I believe the rest of the range are the same as brand x, do if you want one, pressgang CRC into bringing them in. 🙂
To me, it'd be perfect for a hardtail, but in a fan of suspension posts anyway. 🙂
Posted : 22/12/2019 8:14 am
“Thanks, I appreciate the actual numbers but in real world terms and effect, compared to the amount of movement in saddle flex, padding clothing, skin and muscle: sweet FA.”
They’re not actual numbers and once you include dynamic loading and the big horizontal component of forces when you hit bumps, there’s no doubt that a small diameter “rigid” post will reduce a useful amount of the impacts and vibration. Any benefits are in addition to absorption from everything else.
The usual suspects here will insist that the benefits of frame and post (and wheel) flex are negligible but they’re just proving they have a poor understanding of the subtleties of engineering and the sensitivity of humans to tiny improvements.
I’d still rather have a dropper post though!
Posted : 22/12/2019 8:41 am
I've never ridden a HT or FS which wasn't good on steep climbs, admittedly I haven't bought an MTB in the last 10 years, but prior to that owned / rides dozens. Is this really a problem that needed solving?
Posted : 22/12/2019 9:33 am
I think it depends how you pedal. I can often tell if a rider is someone I know from quite a way off by their padalling style. I think upper body lean is a big part of it, some folk like to be more upright than others. (mtb-ers that is.) I like a fair amount of lean, so I don't have issues with more moderate seat angles even on v. steep climbs.
But I don't quite get the comfort thing. Surely one is standing on the pedals long before that becomes an issue?
Posted : 22/12/2019 10:03 am
Yes! Because then frame designers can reintroduce slacker seat angles and steeper head angles with a slightly shorter reach to make bikes more 'chuckable' and 'fun' and around we come 🤣
But I don’t quite get the comfort thing. Surely one is standing on the pedals long before that becomes an issue?
I think the comfort thing comes from people who are coming off an amount of time on a FS, I get really lazy if I ride a FS for a few weeks cos you can just sit down and bounce/roll over stuff. They're not so much 'uncomfortable' as 'shouldn't expect as easy a ride over small bumps as a FS' and 'need to be ridden slightly differently to a FS'.
Posted : 22/12/2019 10:14 am
@footflaps - I guess the gist of what I was getting at was the possible different needs of different riders who do winch & plummet rides (say Hebden) V a more traditional XC rider (say Thetford).
Most of the geometry we are talking about will have evolved within the last 10 years or so, so you should definitely hitch a ride on a Geometron or similar to see the contrast.
If it's properly steep & off road you'll need to be seated, and thus the seat angle plays a part.
It's all horses for courses though and any bike will get you out on a ride on any terrain.
Posted : 22/12/2019 10:18 am
@footflaps in my experience, yes it is. Being 6'5" I have always had problems with front wheel lift on steep climbs as my weight is always very far back with the saddle at full height. Technique can help with stopping this but it only helps so much, and it doesn't make for comfortable riding when you're perched on the tip of your saddle and hunched over your bars for any extended period.
Steep seat tube angles have transformed climbing for me, along with longer reach I finally feel like bikes are being made that fit me properly which I now realise has never been the case.
Posted : 22/12/2019 11:11 am
Yes it is.
If you add length to the front centre and send the front axle even further forwards with slack head angles, then reduce chainstay length to 'make it climb better' (open to debate that one) you have a.much more rearward weight bias. Steepening the seat angle brings you forward to being more central between the axles.
But you're not likely to understand that if you've not bought an MTB for 10 years.
Posted : 23/12/2019 12:49 pm
But you’re not likely to understand that if you’ve not bought an MTB for 10 years.
Patronising or what!
Posted : 23/12/2019 2:33 pm
It's wasn't intended to be so. Apologies to any thin skinned types. However, HT geometry and the thinking behind it has changed a great deal in the last 3 years, let alone 10.
It's reasonable to assume, especially from the posters other comments/questions that they might be a bit out of touch.
Posted : 23/12/2019 2:49 pm
Doubling down. Nicely played.
Posted : 23/12/2019 3:34 pm
Offence is down to interpretation isn't it? Subconscious or otherwise. It's basically a choice.
If you're a bed wetting type scouring the internet for things to be offended by, guess what? You'll find offence, even where there is none.
A bit like finding sexism on toilet doors because one is for marked for gents and one is for ladies.
Do I get the triple bonus?
Posted : 23/12/2019 3:48 pm
Yes it is.
If you add length to the front centre and send the front axle even further forwards with slack head angles, then reduce chainstay length to ‘make it climb better’ (open to debate that one) you have a.much more rearward weight bias. Steepening the seat angle brings you forward to being more central between the axles.
I've never heard the short chainstays make it climb better one. Though short chainstays are better for grip on slimy not-so-steep climbs where you want all your weight on the rear wheel.
Posted : 23/12/2019 4:11 pm
That's a pretty specific scenario to utilise as a design brief for chainstay selection!
Short stays seem to be for pop, snap and manualling reasons, in order to get a bike that feels more responsive. I get the logic and for BMX and jumpy style riders, I reckon that's what they're after, but they're less good in technical trail situations IMO, for exactly the same reasons. Depends on your priorities. It's certainly more in vogue than long stays at the moment.
Posted : 23/12/2019 4:35 pm
In the early days of UCI and MTB I think there was a hill climb category and some of those guys had bikes with really short chainstays. I think elevated stays came about from that too.
Posted : 23/12/2019 4:43 pm
LOL.....
What a brilliant thread!
Yeah...... you are right...... when I was out today getting covered in mud and having a hoot ragging around Haldon in the blessed sunshine I suddenly realised that my SA was 0.35 degrees too steep. God, it really brought my mood down. I came home in a real grump.
I forgot all about the Deer I saw and the fast berm at Grumpy Man's Gate that I finally nailed and the smile from that cute toddler who laughed when I pulled a big skid. That amazing hot chocolate and homemade mince pie in the hub cafe was long forgotten when I realised that my 18 year old 26" Rock Lobster Team Tig SL with newly installed 650b's would NEVER be as fun as the latest £10K superbike that MBUK or What Mountain Bike are touting as the next big thing.
God, i'm so depressed. I hate my bike. Think I might take up golf.
Posted : 23/12/2019 6:11 pm
Swap seat tube angle for loft angle:
How to Determine Which Loft You Should Get on Your Driver
Posted : 23/12/2019 7:28 pm
Simon, the reason you're scoffing at the thread is you're riding a sensible bike with a sensible seattube.
Your hardtail experience is unspoilt by modernity.
And you've retrofied your experience even further with those old French touring wheels.
If you were lumbered with one of these so-called "good" bikes, you'd be nodding in along in earnest agreement.
Mountain bikers have never had it so tough.
Posted : 23/12/2019 7:49 pm
Hey Ned......
Are modern bikes really that bad? Have I dodged a bullet by not buying into the marketing hype regarding materials and geometry?
I haven't bought a new bike in what feels like decades as I simply couldn't afford one. (Getting my head around the nearly £2k needed to buy my first and only full-sus back in 2010 was hard enough.)
Always thought that the crop of new slack bikes reminded me of one of these:
https://www.npr.org/2014/10/11/354875096/behind-the-motorcycles-in-easy-rider-a-long-obscured-story?t=1577132102012
And less like one of these:
https://www.twobros.com/products/honda-cbr600rr-2013-2016-slip-exhaust
I've tried a few modern slack bikes and could never understand or feel comfortable with the "chopper" like flippy-floppy feel of the steering.
Sounds like i've been wise in slapping a pair of 650b's on my "old-skool" hardtail.
Posted : 23/12/2019 8:18 pm
It's great that you're happy on your old bike, but it's really not something to be all smug and superior about.
Modern bikes are just so much faster and more fun, if you ride them as intended.
Posted : 23/12/2019 9:38 pm
yes it is
Posted : 23/12/2019 10:10 pm
Modern bikes are rubbish.
Posted : 23/12/2019 10:22 pm
Weirdly the hardtail I have with the slackest geometry (Stanton Sherpa) is the nicest to ride of all the hardtails I've owned, including various super-steep 26" bikes, which might have been more "nimble" or whatever, but were rubbish to ride in comparison.
And my Cotic FlareMax which is even slacker than the Stanton is a good deal more fun and capable than the Stanton (but the Stanton is still great).
I guess I've drunk too much kool aid.
Posted : 23/12/2019 10:38 pm
No, but you’ve saved yourself some money and you will never miss what you haven’t had.
Posted : 23/12/2019 10:40 pm
