are Pro2 20mm space...
[Closed] are Pro2 20mm spacers the same as Bulb 20mm spacers?
[#2438154]
Just bought a Bulb'd 20mm front wheel and it's missing one 20mm spacer.
Will a spacer from a 20mm Pro2 slot in. You'd think so wouldn't you....
I've got a Pro2 20mm wheel so I could dismantle it and check but I'm busy and .....
Posted : 04/02/2011 10:37 pm
Don't believe so
No.
Posted : 04/02/2011 10:39 pm
No
Edit: too slow.
Also, on the bulb, 6 bolt spacers are different from the spider type.
Posted : 04/02/2011 10:40 pm
No. Bulb disc side is larger than non disc side. Pro II are both the same size.
Posted : 04/02/2011 10:42 pm
bugger, and cheers.
Now who has a spare non-disc side.......
Posted : 04/02/2011 10:53 pm
Hi mte strangely enough i have a set for a bulb here if you want to pm me it's in my profile ok mate.
Bats.
Posted : 04/02/2011 10:55 pm
reggie - believe you bought those from me. The spacers were definitely on when i boxed them up. Which side is missing? I'll sort you another one out.
Posted : 04/02/2011 11:02 pm
nodrog2 - indeed. I've just emailed you. It must have popped off in transit. If you have a spare in the tool box then that would be great (non-disc side).
Otherwise I'm happy to buy yours batman.
Posted : 04/02/2011 11:08 pm
now sorted. Cheers nodrog 8)
Posted : 04/02/2011 11:29 pm
no problem mate.
Bats.
Posted : 04/02/2011 11:34 pm
