Apart from counting...
Apart from counting and measuring
Is there any easy way to see which ultegra cranks and cassette is on my bike ? Is it written somewhere on the cranks or rings ?
Just trying to avoid having to manually count if I can tomorrow when I set them up in the e tube project app. Crank length is from the center of the bottom bracket spindle to the end of the crank isn't it (so I just need to measure this I presume)
Posted : 01/02/2025 7:23 pm
Should be written on crankset somewhere, usually, unless it's worn off. I forget where it is on cassettes.
Although, counting tip: count 90⁰ around the ring, and multiply by 4. Much easier than losing your place on a full circle.
Posted : 01/02/2025 7:32 pm
Crank length is on the inside below the pedal hole. Will likely be 172.5. If the chainring looks smallish, it’s a 50, otherwise 52. Count a quarter round. Cassettes you can usually tell just looking at them. 28 looks big on a road bike,  about 5”across. 32 is huge and unlikely, 25 sleek and it won’t be a 23. Smallest sprocket will be 11/12.
Model number is identified on the inside of the crank. Ultegra starts with a 6xxx. How old is the bike? How many speeds. I have 6600 (silver), 6700 (black) with five arm spider and 6800 black 11spd with four arms. All are 172.5 length.
Posted : 01/02/2025 7:39 pm
Thank you all. I will do that as soon as I get home
The bike and the group set is absolutely brand new. It's only had about 130 km on it so I don't think anything's worn off yet:) it's just a little bit annoying that the manufacturer doesn't list on their web page. What option they ship with the bike ( pinarello X7) - unless they do and I am blind
Q
Posted : 01/02/2025 8:49 pm
If you do have to measure crank length then it’s centre of BB spindle to centre of pedal spindle, not the end of the crank arm.
Posted : 01/02/2025 8:58 pm
thols2, J-R, J-R and 1 people reacted
Nice bike!  Looks like  long cage rear derailleur, so I’ll go with a 32 on the back and a 50/34 on the front. I could count the teeth on the picture. Will be a 172.5 crank if you are average size 54/57 frame.
Posted : 01/02/2025 11:00 pm
What about if you have a set of these? Do you measure around the outside or the inside? Maybe both and average them?
zXcIM
Posted : 02/02/2025 12:35 am
Thanks all
Whilst pinarello's site doesn't list it checking the website of the shop that I bought it from, lists all the specifications broken down by bike size
Apparently I have
Crank 172.5
Chain rings  50/34t
Cassette 11/34
Which sounds about right but I will vaguely double check today
Posted : 02/02/2025 7:48 am
Nope.  You measure from the centre of the bb to the centre of the pedal axle.  Make them whatever shape you want, it doesn’t alter the c2c distance.
Posted : 02/02/2025 7:51 am
tillydog, leffeboy, tillydog and 1 people reacted
I suspect it was a tongue-in-cheek comment from thols 🙂
I remember the furore in the early 80s when these were resurrected (again) by PMP. They've been around for a century to date and won't go away because it seems that a few people felt an advantage, even Ian Cammish a champion time-triallist BITD
...the arm length is clearly stamped "175", indicating somebody at P.M.P. understood it was simply an odd way to make a 175mm crank. http://pardo.net/bike/pic/mobi/d.pmp-cranks/
Posted : 02/02/2025 8:42 am
alpin and alpin reacted
Posted : 02/02/2025 8:47 am
