Anything better tha...
[Closed] Anything better than Hope XC for the money?
 PJay
[#9597604]
I need a pair of 29er/700 wheels. I'm not entirely sure that bike will fit into a particular category but it's going to be a sort of gravel/utility bike/monstercross frankenbike.
I probably won't want tyres bigger than 2.0" or narrower than 40c; would a pair of Hope XC wheels suit the bill and is there anything else I should consider around the £300 mark?
Posted : 09/10/2017 6:32 pm
 PJay
Any thoughts or anything else I should be considering?
Posted : 10/10/2017 6:44 am
They're what i've recently bought and they're lovely 🙂
Posted : 10/10/2017 6:45 am
Think Stans crest wheelset would be fine too? Not seen prices recently but they used to be available for around £320
Posted : 10/10/2017 6:47 am
Hope all the way PJay, you know that 😉
Posted : 10/10/2017 6:54 am
Ive been pondering the same issue....my wheels need replacing, due to cracks round the spoke hole...
I've decided to go for hunt for a couple of reasons. Half a mm wider internal, lighter than hope xc, have a weight limit of 115kg loaded and come with tape and valves, plus the adaptors I want.
If they mess me about though, it will be the hopes!
Posted : 10/10/2017 7:20 am
My main reason/thoughts were based upon my LBS retailing the HOPEs, even though i paid a bit more, he won't mess about if any issues/problems, they'll just be sorted. Customer service is sometimes worth a little extra.
Posted : 10/10/2017 7:23 am
if it's more gravelly/road then some handbuilts with Hydra rims and Hope hubs would be potentially tougher with higher pressures. But if it's lowish pressures then the Hope hoops are good VFM.
Posted : 10/10/2017 8:37 am
DT Swiss that fit the budget, Mavic that fit the budget, Stans, something built by Superstar or American classic
Posted : 10/10/2017 10:53 am
 PJay
I do like my current 26" Hope wheels (Pro IIs). The current Hope XCs come with Pro 4 hubs; I realise that they've changed the freehub but will my current crop of Pro II tools work or will I need a new set?
Posted : 10/10/2017 6:48 pm
A quick search and it looks like the Pro 4 uses the same tools as the Pro 2 Evo
Posted : 10/10/2017 7:11 pm
