Are they really that good?
Do they come in 26"?
They seem OK but I can't work out whether the one on the rear should be facing the other way.
I'm using directional Stans fluid now.
Get with the programme grandad.
I hear the 2.4" woods valve version in ano turquoise is a real hit with the yeti kru. ๐
Do they work ok in the Southern Hemisphere?
*Checks date*
[quote=Teetosugars ]*Checks date*
Do you think she uses them?
Only if you ride backwards.
I think there are enough tubes in One Direction without you shoving yours in.
[url= http://www.sadanduseless.com/2014/09/sad-dads/ ]All the same, let us take a moment for all the dads out there, whose daughters love those tubes...[/url]*
*that is a really bad sentence.
Can't find them on CRC or Wiggle?
I got the maxxis directional tubes, the concept's sound but I've ended up using 2 front DHF directional tubes because the rear DHR tube was terrible. I'm not sure whether to run the rear front back to front to make it roll faster, or run it front to front to get some grip back because right now the back keeps trying to overtake the front.
They're good for hill starts
Dual chamber is best, outers forward with puncture protection & Inners rearward for float. Offset valves make tyre logo alignment a nightmare though
If you say "gullible" backwards, really slowly, it sounds like "inner tube"
I fitted a North one in the front wheel, now the bike is unrideable - it always steers North direction...
medoramas - MemberI fitted a North one in the front wheel, now the bike is unrideable - it always steers North direction...
That sounds perfect.
thestabiliser - Member
Doesn't work if you pair them with downhill tyres though.
by accident I blew my tyre up with the valve in the 2 O'clock postion by accident !,upon riding the thing was all over the place..
good job I realised, let it down & blew it up again with it in the correct 12 o'clock position....I wont do that again.
