Bike was weighed on LBS scales, given a 5pro weighs around 28lb add 1lb each for shock, post and forks I thought 31lb would be about right.Don't care anyway, rides superb. Do it BMC09 you'll love it.
anything under 35lbs tends to get blown off course on rooty off camber corners in anything past a 10mph breeze.
I would rather be on an Alpine in all conditions over a five am. For trail riding go with a five with 140 kaskima float up front and ccdb & maxle at rear. The toughest decision is which colour to go for!
It's worked out far cheaper because I've not needed to get it serviced since it's been on the bike due to the fact it's very basic tech I reckon. I ride everything from trail centres to secret natural black graded trails and some DH tracks, so it gets a fair bit of abuse.
My air shock on my XC local/evening ride bike needed annual servicing at £100 a time over the same period. (swapped that for a HT now)
And both bikes got ridden on 2-3 hr loops every week.
So by comparison it's been far cheaper to keep the coil shock on the 5.
Rik, I didn't use the terms Cheaper and CCDB in the same sentence, or even the same post. However, you did. Not sure what you mean there fella.
My point was the heat management is better with coil shocks which offsets the oil degradation to some degree.
The insulating properties of the air sleeve and added friction from the air seals are the issues I wanted to get across. Coupled with the more compilcated internal porting to accomodate muliple platform settings. This leads to shocks that run hotter and cavitate faster, EVEN IF you carry out regular air sleeve maintenance.
The CCDB reference was due to the fact it allows for all the adjustment and gets even better results with less fade due to the way it ports the oil.
I don't do marketing BS I just cut it down to basics. Some folk don't appreciate that, but I can't do much about it. I just tell it like it is.
I thought you serviced suspension for a living?
Plus the CCDB service interval is the same as an RP23.
I do, but I'm mindful that people reading these threads have to pay for servicing.
The RP23 is also a high performance piece of kit. So the service intervals would be the same.(the fact it's fitted to a wide range of bikes as OEM equipment doesn't alter this)
I service my kit when it needs doing, and I service customers' kit when they request it.
I mainly service forks these days, but I trained with Mojo Race technicians a few years back. And I'm also qualfied to service Manitou, Maverick, Marzocchi, Pace, and Rockshox.
But if it ain't broke,I don't fix it. I advise the customer on what they may need, ask them what they want doing, and then deliver it.
I have a 5 with 36s up front and a CCDB out back, it's incredible. So good in fact I ditched my DH bike and my XC bike and just ride this one now. It's great up and down, whether that's in the Alps, uplift days, all day trekking, whatever.
The balance of the bike does change with 36s up front instead of 130/140mm forks but I wouldn't say it was for the worse, it's much more stable on rocky downhills, which is why you buy a 5 and stick a CCDB and 36s on it, right? 😀
Coil U-turn lyriks and CCDB with Ti here. I wanted something I could ride at Cannock/Wales and at the same time do the Mega on. Alpine160 seemed overkill for what I needed and the Five does everything I want. Run the forks at 140mm for UK riding, bump up to 160mm for severe stuff. As for the RP23 to CCDB swap, I could never get the RP set up how I wanted it. The CCDB is an awesome bit of kit and feels much better suited to the frame.
Different strokes for different folks though. I use mine for a lot of DH based jumpy stuff and I'm quite a big chap so the original forks and shock bottom'd out a lot. Doing this all day...
...ended up buggering the rear shock which then had to be replaced. I don't really do all day riding in the hills sort of stuff so weight isn't really an issue to me. I can see how it would be to some though, but the adaptability of the frame lets you run it either way. Thats why Fives are great!
