Anyone not get on w...
[Closed] Anyone not get on with wide bars?
[#7032366]
Done a few rides on the Patriot with 760s and they just feel wrong.
They are flat, I raised the stem to compensate - so I may get on better with risers. But I'm just dying to put the 680s back on, it felt soo much better. I had a 70mm stem with the 680s and I put a 50mm on to compensate for width.
Anyone else go back?
Posted : 30/04/2015 4:18 pm
I've gone back down to 710/720 after trying wider for a while, I can't personally get on with anything much over 720 as it starts to limit my movement.
But playing devils advocate 'Done a few rides' implies you might not have given it enough time to move from just feeling odd because it's different, I spent a good few months trying things out before I started going back down.
I still get on just fine with 660 and 680 on more racy bikes but it seems my natural comfortable width is about 710.
Posted : 30/04/2015 4:22 pm
Me.
720mm is about maximum round here if you don't want broken knuckles on the trees on a regular basis. I run about 700.
Posted : 30/04/2015 4:23 pm
Depends what you're riding. Loved 760 bars riding the DH runs at Morzine. Didn't really like them much on pedally UK trails. Around 710 feels a lot better for me on a trail bike.
Give it a few more rides, my guess is you'll feel very differently if you do go back to 685. If it's an old Patriot with a shortish tt then big wide bars pulling you forward is less than ideal.
Posted : 30/04/2015 4:26 pm
I bet when you go back to 680's they'll feel horrible.
move the grips/controls inboard to see what width suits.
I was liking my 780s until I punched a tree last week and broke my wrist. Not feeling quite so enamoured now.
Posted : 30/04/2015 4:28 pm
760 or so is good for me but I didn't get on with them at 800mm, which is what my bike came with.
Posted : 30/04/2015 4:33 pm
Sort of. I do like the feel of wider bars, but having caught a bar end (yes, I do have grinder grips on my SS) on a tree and somehow walking away with only scrapes last year, I have to balance that against actually fitting through gaps.
I have moved from about 670 up to about 720, over the past few months but any wider and i get nervous.
Posted : 30/04/2015 4:37 pm
Trail riding I use my 740 Renthal Lites, for uplift stuff I have 780 Funn Full-On bars....horses for courses isn't it?
Posted : 30/04/2015 4:38 pm
davosaurusrex - Member
Definitely sounds like the bars were at fault here.
It's a 2007 and I think this is part of it. Geometry doesn't seem right.
I'm happy to persevere with things and fine tune over time - I've had the bike for 8 years - but this just feels worse in every respect. I think they are too low for starters so risers might help. I could get the riser 760s and trim them down - after all 710 is only slightly wider than 680.
With 680/70 it felt like a proper all day up and down bike, despite being long travel I could use it for everything. With 760/50 it feels good on the descents but flippin hard work on the ups.
Posted : 30/04/2015 4:41 pm
I like the 750s on my new bike and wouldn't previously have thought about anything longer than my 680s which I thought was plenty. Unfortunately there are some places in Stanmer where 750 doesn't fit unless I slow and shimmy.
Posted : 30/04/2015 4:45 pm
Not for me I run 35mm stem and a 760 bar, I would prefer 780 but I hit too many trees with them...
Posted : 30/04/2015 4:46 pm
I tried 760 for few weeks. Quite nice downhill, but otherwise "nah!". Came back to 680...
Posted : 30/04/2015 4:50 pm
 kcal
recently upgraded to wider* bars on my HT and they felt quite good.
* 580mm to about 630mm I think.
Posted : 30/04/2015 4:54 pm
I'm the exact opposite. 800's on my only MTB now. I rode my wife's bike with 750's on it & they felt awful.
But, I am 6'2" with long arms.
Posted : 30/04/2015 4:55 pm
If your bike is already short/your on the frames size limit, small changes make a huge difference and not always for the better (it's definitely not as noticeable with a frame that is slightly too big for you), as I found out 3 stems, 3 different bar heights and 2 seatposts later! I run a 740 mm 25mm riser bar, 60 mm reach 10° rise stem with 2 spacers.
You've changed 2 variables the bar height and reach, so obviously you could be too short, too low or combination of the two upsetting the COG.
When my bike was too short it felt like the front wheel wanted to fold under in fast berms and my knees felt very close to the bar, it was sketchy on anything technical. Bar height too low made the bike a chore to ride, needing more input to keep it balanced with a dose of lower back pain to boot.
Unfortunately it will take a bit of trial and error to get right, unless you have a bike fit.
Posted : 30/04/2015 6:58 pm
Doesn't this all depend on how tall you are and how long your arms are? One persons 68cm is someone else's 76cm....
Posted : 30/04/2015 7:01 pm
It's funny, when I first used 750mm bars I didn't really notice a massive difference. Then tried my other bike after a few rides on the 750mm bars at the 685mm bars felt horrible! 750mm works for me. Some it won't.
Posted : 30/04/2015 7:02 pm
 ton
i have probably got the widest shoulders on the forum, and i hate silly wide bars.
bars should be a inch or so wider than your shoulders, no more.
700mm is far too wide for most people, it is a fashion thing and nothing else.
Posted : 30/04/2015 7:03 pm
Use whatever size you like. Do give it a fair crack though, I tried 760s a couple of years back and didn't like it (also rode into a bunch of trees), tried again more recently on the same bike and found it much better. 760 seems to be my limit but anything less seems weird now. My commuter has 750s 😳
It's like anything else, it might not be for you, but even if it is it's new and weird and could take some getting used to.
Posted : 30/04/2015 7:12 pm
Ton, I respectfully disagree.
It comes from DH racing where wide bars can offer leverage to keep the front tracking straight and true through some horrendous terrain, try levering your front tyre out of a rooty rut, football sized hole etc on a DH course with narrow bars...it's not impossible and I'm sure the heroes on here would say they'd skim across such terrain without getting held up anyway....but for mere mortals a nice wide bar to put that front wheel exactly where you want it and to get it out again is invaluable.
The more uplifts I do the wider my bars have gone as my riding has progressed, currently using 780 but jumped there from 740 so may settle on 760.
Now, if you're just trail riding around flat XC orientated terrain then I'd agree with you that it's purely a fashion thing!
Posted : 30/04/2015 7:20 pm
If you get in a push-up position on the floor, the comfortable position, is a good place to start with for bar width.
Posted : 30/04/2015 7:21 pm
Can of worms there Martin! Are we talking wide placement push-ups for chest work or narrow hand placement for a tricep workout?!
Posted : 30/04/2015 7:24 pm
I think you answered your own question there, but as its singletrack your probably right!
Posted : 30/04/2015 7:33 pm
I dunno. 750 felt WEIRD to start off with, and now it feels normal. But it's a very weird sensation so I understand why people don't like it. I've just 'upgraded' to 785 which also feels WEIRD but I suspect will be OK once I've got used to it.
I generally find the wide bars are a bit of a hinderance on uphills and flat and great on DH. YMMV depending on what you ride.
Posted : 30/04/2015 9:08 pm
I would like to try wider bars but I'm finding 720 too tight in some local trails and I'm not rad enough to manual and twist the bars as I pass through the trees.
Posted : 30/04/2015 9:11 pm
Pff, as if anyone on here's ever done a pushup. Log on your main account and your troll account. Set up 2 keyboards so you can argue with yourself. When you find the optimum position for typing !!1!, measure that distance, that's your bar width. Not that you own a bicycle.
Posted : 30/04/2015 9:14 pm
710 is about my limit, I reckon.
But I'm not very tall, so any wider would be silly. Took a while to get used to the 710s to be honest.
Posted : 30/04/2015 9:46 pm
I'm 5'11 and very average, although I'm told I have broad shoulders.
Re the bike, I don't know how it compares to a more modern one.
It's an 18 so on the small side of normal probably.
Posted : 30/04/2015 9:48 pm
if you're comfy with 680s there's no law says you can't use what you want
Posted : 30/04/2015 9:49 pm
Yeah I know, I want to know how much of a freak I am 🙂
Posted : 30/04/2015 9:52 pm
I am an XC type rider and always have been (mainly because where I live is totally unchallenging technically). I tried 685 for a month and and now back to 620.
The extra width almost feels like it slows me down with a wider stance. If I rode other styles I would no doubt see the benefit.
Posted : 01/05/2015 7:35 am
yep, I'm also an xc rider, tried and hated wide bars (700mm) and have now gone back to my trusty 640mm with bar ends!
I was always moving my hands inwards while riding with the 700 bars, while also feeling less confident on techy climbs.
Posted : 01/05/2015 7:45 am
Isn't it about time the bike industry responded to this sort of issue so we can switch bar lengths to what trail we are riding that day. A QR system for grips, brake/shifter clamps and stem would cure this easily.
Then we can have longer bars for downhill/gnarrr/fat tyres and switch back to a 3mm shorter bar should a bit of forest singletrack be on the days menu.
expanding on that it could open up a whole new market in backpack bar quivers to so in-ride swaps could be made.
Why am i telling you lot, I'm off to the patent office straight away! This time next year...........
Posted : 01/05/2015 8:42 am
 Del
went 740 and 50mm stem from 711 and 70mm. wasn't happy. i mean, it was 'ok' but not great. went 60mm stem - perfect. just felt instantly right.
Posted : 01/05/2015 8:59 am
For the record, I'm 760mm and 35 stem, tried a few combinations and this works best for me
Posted : 01/05/2015 9:04 am
 poah
I've gone 620-685-711-750 and they feel a bit weird at first but I soon forget about it. I recently crashed with my carbon 750s so I'm replacing them with a spank oozy 760 vibrocore. I think that will be the limit for my shoulders and bike though. I move my hands inwards on climbs
Posted : 01/05/2015 9:32 am
Tried 750s for about 9 months. Didn't feel like I gained much from them. There were times they were better, but times they were worse too. Have gone back to (carbon) 710s which seem to cover most bases quite nicely, and saved a whole chunk of weight.
Posted : 01/05/2015 10:10 am
In 2008 i swapped out a set of 670 for 780 bars on my 07 Mongoose and loved them. The only problem was that we kept trashing the door frames when wheeling it into the house. Cut them to 750 and that made it just narrow enough to not be a problem. Both the wife and I are currently running 750-60 (hers are wider as I got her old ones) and now I have a garage again I'm saving to swap to 800mm wide bars as I prefer the width, she's significantly narrower so is keeping hers.
It's all about what suits you and your style, my Orange Alpine is my do it all bike and rides better with wider bars - for me. My little bro still prefers narrower bars 690-710) and they've never slowed him down. But that might just be cos he's a grumpy cheapskate and hates new things.
Tom KP
Posted : 01/05/2015 10:14 am
[b]kerley - Member[/b]
[b]oliverracing - Member[/b]
What wheel size out of interest?
I had 685 on my old 26" wheel anthem, nice carbon MT Zoom bar. So when I got my 29er I took the stock 720 bar off it to save weight with the MT Zoom. Christ it felt ridiculous trying to steer the big wagon wheel where you wanted it to go.
So naturally I didn't put the 720 back on, I bought a 740 flat bar to go wider again and go a little lower.
I think its just what you are used to and what feels right from person to person but the only trouble i have with wide bars is the gridding and having room to fit them in alongside the other riders!
[i]Isn't it about time the bike industry responded to this sort of issue so we can switch bar lengths to what trail we are riding that day. [/i]
Surely a pair of Reverbs sticking out the stem so you can carry out on the fly adjustment would be best?
You could even have different width on each side at will so your outside arm has a longer bar to turn than your inside one when cornering?
Posted : 01/05/2015 10:16 am
Aah yes.. I'd forgotten about this. My first 29er seems to need a much wider bar than I would have used on a 26er, due to having to turn this huge wheel.
The Patriot is 26 of course, which may explain things a bit.
Posted : 01/05/2015 10:21 am
I've got a few different widths on my bike.
700mm on the XC bike, only a smidgen wider than 'normal' raiser bars, feels more in controll, but sometimes miss the really narrow flat bars.
760mm bars on the Pitch when I had it, great, but some issues with tree clearance, best left for more open tracks.
800mm bars on the Fatty, feel great for tha bike, just recieved a set of 777mm bars so will swap them over, not sure I'll miss the width and might swap them again and try some normal bars.
It's good for controll, especialy getting it back under control after a slide or holding a line over rocks/roots, but I'm not convinced it's a particularly good ergonomic soutuon.
Posted : 01/05/2015 10:27 am
