Anyone make me 2 of...
[Closed] Anyone make me 2 of these - metal fabrication - 20mm axle holder
[#5175971]
Or where can i buy similar from?
Posted : 21/05/2013 9:17 am
Buy some Galvanized conduit make your own.
Posted : 21/05/2013 9:22 am
expand?
Posted : 21/05/2013 9:23 am
Using T's and tube should be an easy job to make yourself, could probably do it using 22mm compression fittings. I take it its for standing bikes up in back of car/van.
I used a short piece of this
plus 4 of these
Posted : 21/05/2013 9:41 am
BTW That's Unistrut, available most electrical wholesalers fairly cheap.
Posted : 21/05/2013 9:42 am
what is the width between droputs on a lyrik
Posted : 21/05/2013 2:08 pm
I have an origin8 bike block, similar thing but has screw in adaptors for 15&20mm forks and Qr's.
eBay Item 230826875603
Posted : 21/05/2013 2:19 pm
rj - given that a front hub is 100mm, the dropout width will be ~110mm I reckon.
Posted : 21/05/2013 2:25 pm
godzilla - are you selling?
Posted : 21/05/2013 2:52 pm
No, just a recommendation. I looked at making one but wanted to be able to use it with 15 and 20mm forks, I drilled some holes in my Berlingo floor and just bolted it in, I'm going to get another some time.
Posted : 21/05/2013 3:01 pm
Actually, I might have a couple of similar bits at home...made some for a mate's rack a couple of years ago.
Posted : 21/05/2013 4:16 pm
Got some 21mm ID tubing and steel plate here, make another nice project for me if you're not in too much of a hurry as i'm a bit tied up for the next week or so.
Posted : 21/05/2013 7:24 pm
coatsey that would be ace cheers
Posted : 21/05/2013 7:26 pm
Will get onto it asap.
Posted : 21/05/2013 7:33 pm
Thats ace - can you do a pair please? How much do you want? Where are you?
Posted : 21/05/2013 7:38 pm
??? how can your forks be wider than the hub!?
Anyway,
20mm forks/hubs are 110mm width
15mm forks/hubs (and qr forks) are 100mm width.
Posted : 21/05/2013 8:03 pm
I knew what I meant, besides, I was almost right! 🙂
Posted : 21/05/2013 8:12 pm
