Anyone made a DIY B...
[Closed] Anyone made a DIY Bike Cam strap/fastener for a normal digi camera?
Tried strapping a digi camera to chest strap on my rucksack to do a bit of filming. Anyone else done anything similar? Methods used? Cheers!
Posted : 11/08/2011 7:41 pm
 rs
end of a tripod cut off and then screwed through visor, can rotate up/down/left/right pretty much any way you want, haven't used it much though.
Posted : 11/08/2011 7:59 pm
Ha! That's cool ! Doesnt the weight of the camera pull the front of your helmet down?
Posted : 11/08/2011 8:02 pm
 rs
nah not really, only issue was especially with that camera, crap frame rate, low resolution and narrow field of view. I have a Panasonic TS1 now which was better but still not as good as the super wide angle go pro's.
Posted : 11/08/2011 8:08 pm
I've made a shoulder strap which involved two strips of metal clamping my bak strap with a wingnut to tighten it up. The metal also went through a cheap camera bag with a hole cut out for the lens.
Bar mount, I used an old light mount with a bolt sticking up for the tripod mount, didn;t work so well that one, kept coming loose even with a lock nut.
I had a really small camera which I just used rubber bands to secure to the bars, that didn't work so bad actually.
The goPro mount is just awesome though, works so well.
Posted : 11/08/2011 8:12 pm
Made a chest mount for my bullet cam / rigged it across rucsac sternum strap. Results were surprisingly good if a little odd looking. Would be easy enough to do for a cam with some rigid foam / timber if you are prepared to faff around
Posted : 11/08/2011 8:45 pm
Thanks for the replies guys. I'll have a go at making something more solid. Funnily enough I used laggy bands on my camera yesterday, worked ok for a while until I hit some bumpy bits.
Posted : 11/08/2011 10:46 pm
Has anyone made a case/harness that allows you to use an iPhone as a chest cam?
Posted : 11/08/2011 10:56 pm
vibration and shaking usually upsets regular didgy cams,
i had some sucess with mounting a compact camera on a a bit of drilled and bent steel on the fork of my Surly Pugsley fatbike and it gave quite a cool view of the tyre and trail in front
Posted : 11/08/2011 11:03 pm
 rs
http://www.bikerumor.com/2011/02/13/pom-cam-helmet-cam-housing-for-iphone-4/
Posted : 11/08/2011 11:09 pm
