Anyone fitted a Bun...
[Closed] Anyone fitted a Bung in to an On One Carbon fork?
[#6013626]
Hi
I have bought an on one carbon monocoque tapered fork, it's completely carbon.
I have also bought a bung from on one to fit, the problem is its so hard to fit.
I have called them and it's the right bung for the fork.
This really should almost push in but it is far to tight.
Anyone fitted one before?
Thanks in advance.
Posted : 05/03/2014 9:02 pm
I had exactly the same issue.
The ID of my steerer was far too small for the two bungs I tried - a KCNC one and an OO one.
I called OO and they sent be a carbon plug meant for an 1" steerer. All was fine from there on.
Bit of a bodge but no issue in use.
Posted : 05/03/2014 9:06 pm
I did the same in calling them, they said if it's tight give it a little knock with a rubber mallet, it's supposed to be tight.
I actually took the bung apart put the bolt in the lower part of the bung to knock it in to get it started, although I put the bolt as far as I could in I bent the bolt and ruined it. They are sending me another FOC.
But I still have to fit it.
Posted : 05/03/2014 9:17 pm
 Yak
The BBB Powerhead Compression Adjuster one just pushes in. £10 from CRC.
Posted : 05/03/2014 10:22 pm
I would phone them back!
It's not right to need to "tap" them in.
Posted : 05/03/2014 10:30 pm
 Yak
I'd worry about 'tapping' one in to fit a carbon steerer. It's not a star nut in a steel steerer!
Posted : 05/03/2014 10:32 pm
