Anyone fitted a BB7...
[Closed] Anyone fitted a BB7 to a on-one carbon fatty fork
 mpw
[#8044114]
I have been trying to get this to work tonight but there doesn't seem to be enough clearance for the mount when you attach it to the fork. The rotor rubs on the mount.
Have I got a dud fork or do I need to do something else.
I have seen pictures of other people who have done this but it just won't work for me.
Posted : 08/09/2016 8:41 pm
The Carbon Fatty Fork is Rear Disc Spaced.
Sounds very much like you have a Front Disc Spaced front wheel, like my default Wazoo.
This is why I bought a £34 Fatty front wheel at the same time as my £89 fork and £5 bung, as that wheel is Rear Disc Spaced. 😉
http://www.on-one.co.uk/i/q/WFOOFAT/on-one-fatty-front-wheel (cannot see them on other site now and they are up to £55 now)
Kayak23 on here got around this a different way, he lathed the disc mounts down by ~4.8mm, which is the spec different between the old and new standard.
Posted : 08/09/2016 9:05 pm
 mpw
Thanks that make sense, I did have an old rear single speed hub knocking about and that fits fine. The really annoying thing is it's a front wheel from on-one. It was this deal:
http://www.on-one.co.uk/i/q/WBOOEELF/on-one-emmental-fat-rim-on-el-guapo-fat-hubs
They also managed to bugger up the rear wheel by sending me a 197mm and not a 170mm. Fantastic looks like i'll have to send back both wheels or the forks or both
Posted : 08/09/2016 9:21 pm
No idea is this would work...
http://www.planetx.co.uk/i/q/WSELSEC/replacement-end-cap-pair-for-el-guapo---selcof-hub
What if you bought the rear 135mm QR hub adaptor, but put it on the front wheel? Would this change the spacing?
Posted : 08/09/2016 9:27 pm
I paid local engineering firm to mill down a brake adapter which has worked fine. Cost £25 for their labour and £10 for 2 basic adapters so ive got a spare.
Posted : 08/09/2016 10:23 pm
 mpw
n0b0dy0ftheg0at that's a good idea but i've had the end caps off the el guapo hub and that's what the end caps are already.
I might go down the mill route and get adapters modified
Thanks for your help anyway
Posted : 09/09/2016 8:10 am
