Specifically in Chris King hubs.
Safe enough or will I die?
Did it feel like your front wheel was going to fall out?
Uaed a set on some hope Pro4 6 bolt hubs. Works an absolute treat.
I've used a home made spacer on a King hub and not died yet.
Yes on DTSwiss hubs. Nicely made though was a bit annoyed they did not come with the ring that holds the adaptor in place (meaning I can't sell the 15mm ones I took out.)
Work great on Hope Pro 2 EVO
Fitted mine to Hope Pro 4 and immediately forgot it was there.
Yes on DT, very nicely made and robust.
I was going to get some before I realised you can get a £5 kit of spacers that does the same thing.
The cheap ones I saw would fall off when you take the axle out, these ones replace the end caps.
bigjim +1
I've got the Velospeed one that works perfectlectly well, but is a right faff when dropping the wheel out.
I've ordered the MRP version as it's bugging me a bit.
Buy cheap....
