Does anybody bother, or do you just set it up and forget about it.
Do air shocks suddenly get punctures (rapid loss of pressure) while out on a trail so to speak?
of course I cary one
You need different shock pressures for climbing and descending at trail centres
I also carry spare tyres to swop over for the rocky or muddy sections 😆
I carry one. I've changed pressures on the odd occasion.
i tend to carry one. if a fork is leaking air then it can save your ride.
however, i have only once needed to use it on the ride (on a friends bike) when his fork suddenly lost air.
not a huge extra weight to carry, and as i said above can save an uncomfortable ride home.
Sometimes. Don't so much now though. With a new fork/bike/frame/shock then its worth taking so you can tweak the pressures to work out what works for you though
I carry one as it doubles a regular pump too (spesh windpipe).
I have been known to add a bit of air now and again when I've got a long ride home on the road and want to firm things up or if sag is sapping energy from my ride due to a change in terrain eg from rocky high ground to sandy woody low ground.
I don't normally although do at the moment while fiddling with new bike settings.
Could have done with one in Spain last year when a mate's rear shock started losing air about halfway through the day....although I think it would have required very frequent top ups.....
i carried one for three months on a rigid bike!
Yes I carry one most of the time.
Seem to lend it to a fair few people who have needed one & don't bother carrying kit they might need.
Carry one. Once managed to rescue a mate's ride by letting down the shock pressure to free up a jammed chain then repressure.
On a new bike - yes - makes setup easier as you can do it as you go rather than ballpark car park testing.
after that, i wouldnt/never did/never will 🙂
