Any point in a 20mm...
[Closed] Any point in a 20mm capable hub with 15mm so popular now?
Just for general trail/XC type riding and forks.
Choice of 2 front hubs - one can take 20/15/QR, other can take 15/QR.
About 70g difference in weight and it's only at the hub, not where it matters. 20mm hub does have bigger bearings though.
Posted : 08/12/2014 9:46 pm
I'd go for the everything compatible if the hubs were equal, depends what the options are.
Posted : 08/12/2014 9:47 pm
next standard will probably be 21.25 or something, so I doubt the 20 will truly be useful if you don't already have a 20mm fork
Posted : 08/12/2014 9:51 pm
I saw after years of taking the piss, the second Fox discovered they'd won the axle war with their inferior 15mm bollocks they decided that 20mm totally makes sense for a trailbike... It's sort of funny, in a head-smashing way.
I'm still swapping between 15 and 20mm forks but if I was starting from scratch, 20mm compatability wouldn't be worth 70g imo
Posted : 08/12/2014 9:54 pm
 mboy
20mm compatibility only really of any concern if you're buying 2nd hand forks, and/or anything over 160mm of travel. Otherwise it's largely redundant...
For now...
Posted : 08/12/2014 9:57 pm
What Northwind says.
Posted : 08/12/2014 10:03 pm
For now...
ahh git..
Ended up going for the heavier rim. The Hope I was going to put on is the same weight (if not a bit more) than the heavier and bigger bearings, chunkier disc brake tabs and compatibility with my other wheels and 9mm QR/bolt up axle won over 68g. Am on the look out for some 2nd hand forks for all 3 bikes anyway.
Maybe if the lightweight hub had more proven longevity and if I was buying new forks/new bike then I agree it would be the other way round.
Posted : 08/12/2014 11:52 pm
Northwind +1.
At 210lbs loaded up, I can't tell the difference between 15 and 20 mm. So I guess the difference can only be felt on DH applications.
Posted : 09/12/2014 8:43 am
