Any one used lockti...
[Closed] Any one used locktite bearing retainer?
[#5102706]
Just replaced the cartridge bearings on a full suss & one of them is too loose ,has any one used locktite bearing retainer?
Does it work ,which grade should I use & most importantly can the bearing be removed in the future?
Thanks for any help.
Jeff
Posted : 25/04/2013 8:28 pm
I have in the past to repair a yeti dh9 swingarm with loose bearings
Worked grand.
To remove em you have to use heat
Oh and i wasnt aware of different grades.... Went to halfords , paid 20 quid for a wee bottle of bearing retainer
Posted : 25/04/2013 10:14 pm
clean both surfaces with a solvent and it sticks like.......
check out their site for the most appropriate one to use.
Posted : 25/04/2013 10:16 pm
Thanks for the replies.
I will pop into a local shop which sells the stuff ,now I know it is a viable solution.
Jeff
Posted : 25/04/2013 10:32 pm
