So has anyone had one apart yet?
Do you mean the Sram one with the plastic cups? If you do these should fit
http://www.chainreactioncycles.com/Mobile/MobileModels.aspx?ModelID=40215
Those are BB30 which are not the same
Problem with Press-fit Shimano is that removing the cups from the frame will destroy them.
Its not an option to replace just the bearings.
Not sure if FSA ones have replaceable bearings.
Same numbers on the bearings, so i I must be missing something? ๐
lipseal, do you know what the bearing No.s are??
What type of press fit are you on about? If it's BB90/BB92 as found in Zesty/Spicys then then best bearing info I've ever seen is here; [url= http://www.bikeradar.com/MTB/forums/viewtopic.php?p=16693697&sid=7b5450e4732705cccb4b1538bf2bd276 ]5th post down by dpaulett[/url]
[url= http://simplybearings.co.uk/shop/advanced_search_result.php?categories_id_src=4475&only_in_cat=1&inc_subcat=1&search_in_description=0&Two_Teds_1=6806&x=0&y=0&gclid=CP7VhZzRn6sCFQULfAodfUCxiw ]BEARING 6806[/url]
TBH the ones from CRC ain't a bad price
[url= http://www.highonbikes.com/sram-truvativ-pressfit-bb30-bottom-bracket-bearings.html ]THESE are cheap also[/url]
timmys
Thanks excellent post!
