Any joy welding a c...
[Closed] Any joy welding a crank arm?
I have bought a white industries crank from someone on stw.the non drive side arm has a split/crack where it has been over tightened.now this isn't a witch hunt and the seller has offered a full refund but I was interested to see if anybody has successfully welded a crank or arm? This is a square drive taper arm.cheers
Posted : 25/03/2013 2:11 pm
First, take your spoon.....
Posted : 25/03/2013 2:13 pm
Steel or aluminium?
Alloy John
Posted : 25/03/2013 2:17 pm
just weld to the bb axle that'll mend it ๐Ÿ˜‰
Posted : 25/03/2013 2:21 pm
depends if you want to weld/clean/polish/display on the mantlepiece, or if you intend to make it like new and then use it.
Posted : 25/03/2013 3:05 pm
I'll sell you a replacement set...
email in profile.
Posted : 25/03/2013 3:06 pm
Steel or aluminium?
Alloy John
Cool. Which alloy, steel or aluminium?
Posted : 25/03/2013 4:14 pm
