I've seen a great deal on a set of 2006 revelations
Would you get the full manufacturers warranty and would there be any issues with the forks lying unused for 3 years?
Warranty should be from date of purchase if they're from a shop. How good a deal is good? They've changed quite a lot since 2006 so you'd want them to be in the region of £250 for air or £190 for coil to be classed a good deal IMO.
£250 for air-turns
i don't know about those forks, but the only question i would want to know is whether spares and parts are available if they need work in a years time, ie when you need to give them a service..
That would be my concern. I'd imagine that having sat about for three years with no use, they may need a full service/ seals etc straight away which would cancel out any savings
Yeah because all that sitting there really takes its toll on forks. 😉
They'll be fine straight off.
Parts and service wise also fine. More than likely to be able to find spares years down the line yet.
Steve
If you're worried about getting spares then call TF Tuned and check with them, though I can't imagine it being a problem.
It should.
A car that's driven rarely will suffer more than a car that's driven, and maintained, regularly.
