Any idea what tool ...
[Closed] Any idea what tool I need to remove kids freewheel/sprocket?
Any idea what tool I need to remove the singlespeed freewheel from a kids bike hub? It is threaded on to the hub and has 8 notches on the inside diameter for a tool to fit, but can't seem to find a tool that matches...
Posted : 21/05/2020 6:04 pm
A screwdriver and a hammer. Pop the blade in a notch and tap it off. You can use a brass rod, which is softer than a screwdriver, so a bit more forgiving, but a screwdriver is fine. There probably is a tool bit it's really not worth it
Posted : 21/05/2020 6:13 pm
Gave it a go - not a chance it is coming off like that! Notches are broad and shallow so screwdriver blade doesn't grip.
Posted : 21/05/2020 8:21 pm
If the freewheel is scrap I used to just put in a vice and do vice up tight on the freewheel which squashed it together enough to then just turn the wheel and undo it.
Posted : 21/05/2020 8:24 pm
What kerley said
Posted : 21/05/2020 8:34 pm
Kerley plus 1.
Standard bike shop technique for removal if they're knackered, which is really the only reason to take them off, since it's not a serviceable item.
Posted : 21/05/2020 10:27 pm
Don't you need them off to service the bearings?
I've had luck with a punch and a hammer.
Posted : 22/05/2020 1:26 am
 nbt
Try a BMX freewheel removal tool if you want to buy the RIGHT tool but as above, use molegrips or a vice, it's dead anyway
Posted : 22/05/2020 9:34 am
Don’t you need them off to service the bearings?
I am guessing it being a kids freewheel it is a £5 item so servicing bearings not worth it or may not even be possible. I wouldn't suggest using the vice method on a White Industries freewheel and I would buy the correct tool.
Posted : 22/05/2020 10:10 am
Watch this, pretty foolproof analogy of which tool does what. Used it the other day to ID the tool for a Childs bike of a friend after faffing about trying every tool I had!
Posted : 22/05/2020 10:20 am
