Any FOES/Curnutt ow...
[Closed] Any FOES/Curnutt owners out there?
Hi, does anyone know how you can identify a FOES Curnutt coil spring?
I've got one on my FXR and need to double-check what weight it is but there are no markings on it..
ta
Dan
Posted : 18/05/2009 11:45 am
 luke
Have you tried emailing Foes, Dan? There a pretty helpful bunch.
Posted : 18/05/2009 11:53 am
I spoke to Jamie @ Balfa (01235 759366) as he is now the Foes importer t'other day about this when i had my fly refurbed. I think the best bet is to go to a good motor cycle shop and see if they can test the spring rate.
Posted : 18/05/2009 12:01 pm
Is that the one that looks oddly like an air shock Dan?
(Sorry couldn't resist even though its not that funny)
As you were.....
Posted : 18/05/2009 12:25 pm
Hmmm, well I guess I could also post the spring when I send the shock to Balfa to be serviced / re-valved.
I was just wondering if there was a way of figuring it out from the thickness/number of coils... and hence saving myself the postage cost (tis a heavy old lump of steel).
cheers peeps
Posted : 18/05/2009 1:02 pm
Im afraid im not sure even balfa will be able to identify it by eye but you might be lucky - give jamie a call and see if he can enlighten you.
Posted : 18/05/2009 1:09 pm
Hmmmm
OK so it seems the FOES FXR I bought secondhand came with a [b]450lb[/b] spring instead of the [i]350lb[/i] I was told it had.
No surprise that I was only getting 3'' of travel out of it then!
Posted : 02/06/2009 9:19 am
Out of interest how did you identify it in the end?
Posted : 02/06/2009 10:40 am
Ask IWH, as your trusted friend and owner of many foes he should be able to help....
Posted : 02/06/2009 10:44 am
eh?
Posted : 02/06/2009 10:49 am
[i]Ask IWH, as your trusted friend and owner of many foes he should be able to help.... [/i]
Can you guess who I bought the frame from then?
re identification - Jamie@balfa measured it's coil diameter and compared it with his stock of springs.
Posted : 02/06/2009 1:51 pm
