Not sure if begging is allowed, but i'm a few beers in and like the look of an easton haven carbon bar. Will happily pay forward / back any code received.
yeah hold on
CRCT26QTC7P1
and as a bonus
CRCT35ODZYCH
edit it might be
CRCT350DZYCH
thanks very much, but neither code seems to be working. i tried through a quidco link, might that be screwing it up? will try again
edit- you do not qualify for this promotion, check t+c's. bizarre
You can always singup to their newsetter for 5 off.
For some reason the signup discount code seems to be permanently in my account every time I order over 50 🙂
you'll need £50 in your basket for £5 off
both still current though
easton haven carbon bars for 104.99 so should be expensive enough. i'll keep trying! and thanks very much again for the code!
hmm, dunno then sorry. I checked and I wrote the code down correctly. Maybe they expired.
[b]easton haven carbon bars for 104.99
?[/b]
They are only £77.99 on CRC.....
erm, you need to sign in to apply it 🙂 #beerfail. worked fine though, so thanks again, much appreciated!
I used the top code, so the other one is still up for grabs and i'll post mine if / when i get one.
i went 35mm [url= http://www.chainreactioncycles.com/easton-haven-35-carbon-riser-bar/rp-prod125099 ]#soenduro[/url]
