Antichain Suck Thin...
[Closed] Antichain Suck Thingy ~ Tomac K-Edge???
 P20
I need an antichain suck device to save my carbon 456 chainstay. I've seen the Tomac K-edge, but I can't find any to buy. Looks like a good option, anything similar?
Posted : 02/08/2011 9:34 pm
A crafty bit of moulding with Isopon p40 has worked ok on my Cove but that's alloy!
Posted : 02/08/2011 9:44 pm
I have one on my steel 456 only called into use once and it did the job a beaut
well recommended i got mine from wiggle
Posted : 02/08/2011 9:50 pm
 P20
Salad do you mean the Tomac?
Posted : 02/08/2011 9:58 pm
what do you mean you can't find them? Wiggle sell them. They are the UK importers so pretty much only going to find them there. I want one but £30 is a lot for a bit of aluminium. Just tried to make something out of an E-type front mech bracket but it cant be flipped as it hits the chainring bolts.
Posted : 02/08/2011 10:17 pm
I've armoured my C456 with cable ties, seems to work.
The K-edge is clever, clever enough that I've copied it by sticking a bolt through my Blackspire Stinger in just the right place to catch the chain. Works a charm so far.
Posted : 02/08/2011 10:23 pm
I have a load of cable ties too. But still managed to get chain suck the other week. Cranks are off now and not going back on until I make something like the K-edge.
Posted : 02/08/2011 10:30 pm
 P20
I've currently got this:
[url= http://farm6.static.flickr.com/5305/5598097792_20663d9233_b.jp g" target="_blank">http://farm6.static.flickr.com/5305/5598097792_20663d9233_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/66452821@N00/5598097792/ ]Custom Chainstay Protector[/url] by [url= http://www.flickr.com/people/66452821@N00/ ]ritcheyp20[/url], on Flickr
But I was cleaning the bike yesterday and it's got a great big hole in it 😯
I've now found the K-Edge on wiggle, cheers. I was looking under Tomac last night
Posted : 03/08/2011 7:47 am
I keep looking at the K-Edge for my Inbred and then not buying it as it's quite a lot of money for what you get.
Could probably get something made for less, but it's just finding the time to measure up & get it done.......will probably end up just getting one of these K-Edge ones.
Posted : 03/08/2011 8:04 am
 nuke
[i]I keep looking at the K-Edge for my Inbred and then not buying it as it's quite a lot of money for what you get.[/i]
I've just bought one for my Inbred 853. When it arrived I did think £30 for that! However, if it does the job and protects the chainstay then it's money well spent imo....cheaper than a new frame or new chainstay.
I do what I can with my Inbred 853 frame to prevent damage/chainsuck in terms of zipties and deore steel rings but when the winter mud comes it's very hard to prevent.
Posted : 03/08/2011 8:19 am
Hold fire!
I bought a k-edge for my c456, but the chainstays are so deep in profile that it has to be pointed down at some angle. This reduces it's effectiveness, and I still get chainsuck.
I'm resorting to cable ties, but fwiw I mailed pictures of what I thought were some fairly horrible gouges to on-one, who were very reassuring about that part of the bike being very strong, and not to worry...
Posted : 03/08/2011 8:21 am
nuke - Member
Yeah, probably one of those things that you are glad of once fitted. It's just that 30 mins with a set of calipers, a bit of Solidworks and a friend with a CNC mill would yield much the same result. It's just finding the time to do it....
Posted : 03/08/2011 8:30 am
 P20
Hold fire!
Bugger. Just hit the button about 10mins ago. Oh well, will see what happens 🙄
Posted : 03/08/2011 8:31 am
I run my c456 singlespeed and having fitted a k-edge to my sons Cotic had planned to do the same to the 456 if I ever put gears on it - bit disappointed if it's not going to be a goer.
Maybe I'll have to go 1x10 and fit a chain device 🙂
Posted : 03/08/2011 8:40 am
Wish I had gone 1x10 as I ended up buying all new stuff for mine.
P20 - I had the bear can protection -it lasted 0 chain suck - it's amazing how much damage a chain does.
Fadda - got any pictures of it fitted? I didn't think it was going fit. Damn. You just saved me finding out myself though as I had finally given in and was going to buy one.
Posted : 03/08/2011 8:43 am
I'll take some pics tonight (it's still on at the moment), and post.
Edit: I should add that I think it does help, but this is not as effective as it might be on a different bike. My chainrings seem to run very close to the stays. I went from 3x9 to 2x9, with the idea of moving the chainline out a bit, but can't see how to achieve that; I've now got a larger (26t) inner ring that runs even closer to the stay than the 22t one did!
Posted : 03/08/2011 9:33 am
yep I have the K-edge jobbie tis the same as the tomac
Posted : 03/08/2011 4:00 pm
K-edge make it. Tomac fit them to their bikes.
Fadda - I almost went 26-36 myself but kind of glad I havent now.
Will b interesting to see the pics. If you are using HT2 style cranks there isn't really any way to change the spacing as the BB shell is 73mm 🙁
Is a double specific crank any better? no the SLX style with a bash but the XT or Sram ones? I think they fitted them to the whippet due to clearance problems.
Posted : 03/08/2011 4:07 pm
i've fitted one on my hummer if Tomac use them to protect an expensive carbon swingarm then it's good enough for me .£30 ? yeah but it's well made so........
Posted : 03/08/2011 4:53 pm
 P20
An update on this. The K-Edge didn't fit. It was looking relatively promising, but the inner chainring bottomed out on the K-Edge bracket before the crank arm was fully home.
The set up was Carbon 456, raceface bb with no spacers, K-edge, raceface deus cranks and middleburn rings. I fitted a newer tougher version of the tin can wrap using a steel soupcan and the chain has gone straight through that. Off to look at chainrings....
Posted : 16/08/2011 9:45 am
