Anti Fret Paste
[Closed] Anti Fret Paste
[#7674085]
Just about to change a couple of bearings on my Whyte bike and the service manual states I [b]'MUST'[/b]use anti-fret paste when I reassemble.
What is anti-fret paste and can it be bought in small amounts?
The only one I can find is a huge tub which would last me 10 lifetimes and is expensive
cheers
Posted : 26/02/2016 7:44 pm
Anti fret? I wouldn't worry about it.
Posted : 26/02/2016 7:46 pm
Woodster - boom!
Posted : 26/02/2016 7:47 pm
It also states that anti fret paste must be used in the manual for my 2008 Marin so I had the same problem. Contacted the UK Marin distributors who recommended Castrol Optimol paste which can be bought in a small tube for about a tenner. Think it's to stop the frame and linkage surfaces from corroding together. Always use it when reassembling after replacing the bearings.
Posted : 26/02/2016 11:31 pm
This is what you need.
I think it's about £80 a tin. 😉
Edit: I was wrong, only £58.
Posted : 28/02/2016 2:07 pm
Only £58!!
I just need smaller tube. Would some copper grease do the same job?
Posted : 28/02/2016 5:37 pm
I doubt it, why not try your local Whyte dealer they may have a bit lying around the workshop.
Posted : 28/02/2016 6:12 pm
to be fair that's what I use in similar applications (like my Alpine 160, or the BB30 bottom bracket I've just fitted into my SuperX). Or use a bearing retainer compound to stick them in - you're trying to stop the bearing from moving in the frame and causing damage so you either need a lube with a solid component (the copper in copper grease, which shears easily) or a compound that stops the bearing moving. Different bike manufacturers have different solutions to the same issue - my Nomad bearing kit came with Loctite bearing retainer, and a quick google shows you can buy a tube of "641" for £6 or £7.
If you are that worried about using the "right" stuff I'd be looking at Square Dog's recommendation as £10 is not much for peace of mind?
Posted : 28/02/2016 6:43 pm
