If I have a stages 105 currently fitted to a standard compact, I was to buy a bb30 standard chai set would the stages LH crank still fit okay?
And would there be any issue if i decide to get ultegra and still use the 105 stages crank? Other than OCD....
Posted : 29/04/2017 8:54 pm
You can't buy Shimano BB30 (road anyway) chainsets AFAIK, they're all 24mm spindles. If you got an Ultegra chainset I don't see why (OCD aside) the 105 Stages wouldn't be fine on it.
Posted : 29/04/2017 9:31 pm
A 105 Stages crank won't fit a BB30 chainset and there's no work-around, but it would work with Ultegra and other Shimano cranks.
Posted : 29/04/2017 9:34 pm
Ah ok so sounds like I have to get a conversion kit and fit a normal chain set....
What a faff all these standards.
To make matters worse the 105 crank is silver....!
Posted : 29/04/2017 9:50 pm
