Anchiovy in a road ...
[Closed] Anchiovy in a road Tyre?
Just got a 4mm glass cut right across the middle of the tread on my spesh roubaixseses 😢 if I shove an anchiovy in there will it
A hold
B create an annoying bump on every rotation?
Tell me I don't have to lash out another 35 quid. 😢😢😢😢
Posted : 04/02/2019 7:51 pm
They don't often work that well in road tyres. I'd patch it from the inside.
Posted : 04/02/2019 8:03 pm
Dyanplugs work on tubeless road tyres, stuck one in a Maxxis Padrone and it holds 90psi.
You can cut the tail of the plug off if its noticable when riding.
Posted : 05/02/2019 7:10 am
if itdon't work don't shell out 335 for more Roubaixeseseses. I've got a nearly new pair hung up in the garage that you can have at a serious discount!!!
Posted : 05/02/2019 9:07 am
haven't seen those Dyanplugs before - looks like a good system albeit £2 per puncture cost.
Posted : 05/02/2019 9:23 am
I'd rather occasionally pay £2 a shot for something that works when you need it to, never had much luck with anchovies/bacon strips.
If you get so many punctures that £2 a go is going to be a significant financial burden.. you probably should think about running beefier tyres.
Posted : 05/02/2019 9:31 am
