Alternatives to a F...
[Closed] Alternatives to a Float R shock
My Spicy came with a Float R (apparently tuned for the Spicy....) Anyhoo, it blows through it's travel something crazy unless you load the pressure right up and therefore loose all small/medium bump compliance. Anything more than a 1ft drop to flat and the o ring is off. So, what alternatives should I look at. I'd like to keep with an air shock to keep the weight down but if a coil is the best option, I'd be daft not to go that way.
Posted : 02/10/2010 6:59 pm
put the right pressure in it
Posted : 02/10/2010 7:00 pm
Is it a high volume air can?
Posted : 02/10/2010 7:05 pm
+1 for juggling with pressures.
IIRC the Spicy has a very variable spring curve which is designed to be plush in the initial stroke but will ramp up towards the bottom out.
Even +/- 5psi can make all the difference.
Otherwise, give TF Tuned a call and explain your requirements, they may be able to tune the shock to suit by changing the internal shim stack. I've used TFT a lot (in preference to Mojo) and cannot recommend them highly enough.
Posted : 02/10/2010 7:17 pm
Had a similar thing with the RP23 on my SC, that had the high volume can. Correct sag = blow through travel, more air = loose out on small bump compliance.
Ended up sending it to TF Tuned. All sorted now
Posted : 02/10/2010 7:20 pm
The sag-o-meter is showing less sag than XC and it\s blowing through with a 1 ft drop. If I ran it at the AM setting it would be pointless. Pressure is higher than spec so that is not the problem. I don't really fancy paying TFT, the bike is new so I'm guessing I'll have a pop at warranty. Otherwise a new shock will be on the cards.
Posted : 02/10/2010 7:26 pm
By all means try warranty, hopefully they'll be able to sort something, it may be that you have a dud shock that requires a rebuild or replacement. I've had the mid-travel blow through before on a shock freshly serviced by Mojo, which turned out to be a damaged shock body. I had to run about 5mm sag (on a 130mm travel bike) to take the vicious blow through when boosting off jumps.
I run a Float R on one of my bikes and it behaves impeccably, even when set up with too little pressure.
Posted : 02/10/2010 7:42 pm
