Alphine hub slippin...
[Closed] Alphine hub slipping on certain gears
 GEDA
Got a new comute bike with an Alfine hub. On about the 3rd or 4th gear under pressure it seems to slip though and it grates a bit. Is this normal, should I send it back, and will it wreck the hub if it keeps doing it?
Posted : 04/03/2011 7:34 am
Ill give you tenner for it .
If it is new, get it looked at surely>?
Posted : 04/03/2011 7:38 am
 ojom
Your cable tension may have gone a wee touch. Try re-aligning the yellow marker in i think the 4th position... it might not be the 4th, best check the manual!
That might solve it.
Posted : 04/03/2011 7:40 am
 GEDA
Thanks for that. I was not sure how the gear set up worked so I will have a look and see if it has the correct tension. I would take it to the bike shop but got it from Wiggle mail order to Sweden.
Posted : 04/03/2011 7:53 am
