All you pike lovers
[Closed] All you pike lovers
[#3762361]
http://www.rosebikes.co.uk/article/rock-shox-pike-409/aid:293370/fromtopoffers:1
Posted : 11/03/2012 2:05 pm
This throughly deserves a bump, 409 spec were "alloy steerer and internal floodgate".
The draw back with this 'deal' off-hand seems to be the lack of pop-loc lever going from the info.
Posted : 11/03/2012 3:28 pm
Hi,
How does this differ to a 454 pike? I have a 454 coil already and wouldnt mind this for my second bike...
the 454 is coil, and has u-turn also so whats the difference?
Posted : 12/03/2012 4:00 pm
I believe:
454 alloy steerer and ext floodgate
426 steel steerer and ext floodgate
409 alloy steerer and Int floodgate
...so just the internal floodgate
Posted : 12/03/2012 4:05 pm
I don't need new forks, but for that price I'm very tempted!
Posted : 12/03/2012 4:13 pm
what is internal floodgate? probably one of the knobs i dont use?
Posted : 12/03/2012 4:19 pm
My 409's had a steel steerer. They were heavy, around 5.6lbs IIRC.
Posted : 12/03/2012 4:20 pm
yes.... the floodgate threshold IIRC
Simon, I noted that down ages ago, and have never had these fork, so I may well be wrong.
(I did wonder tbh)
Posted : 12/03/2012 4:21 pm
 nbt
Hmmm. If it's a steel steerer, it might be worth looking at for the tandem....
Posted : 12/03/2012 4:46 pm
I have some 409s - steel steerer, internal floodgate adjust. Heavy, but great forks
Posted : 12/03/2012 5:25 pm
chunkymonkey1982 - Member
If it's internal, then it doesn't have a knob, so you definitely don't use it.
Posted : 12/03/2012 5:29 pm
It has a push-in cover for the floodgate adjust. You pull it off and stick in either a long-handle allen key or you can pull off the rebound adjust and use that to adjust.
Posted : 12/03/2012 5:36 pm
so is the steerer definitely steel then?
Posted : 12/03/2012 5:38 pm
As I've spread rumors and mis-info.. I'll follow that up ... according to these sites.. there a 50g weight difference, so even if it is steel, it's hardly the end of the world. Assuming a 2.5Kg fork isn't too heavy for you in the 1st place 😀
http://www.bikeradar.com/gear/category/components/forks-suspension/product/review-rockshox-pike-426-u-turn-2009-34075
(weight is listed under the specification tab on the top right)
http://www.pinkbike.com/product/rockshox/Pike-409-Coil-U-Turn/
Posted : 12/03/2012 5:48 pm
i'd say so, look the same as mine. I wouldn't let that put you off though - a properly good, bombproof set of forks for £200. You only save 0.5lb with the alloy steerer IIRC
Posted : 12/03/2012 5:50 pm
The main problem appears to be that they are out of stock................ in Biketown what ever that means.
Posted : 12/03/2012 5:52 pm
I think that just means the shop doesn't have them but the warehouse has 3 green dots of availability. Just ordered and they took my money anyway! I'm not bothered about a lockout - do you know if the lever is needed to run the forks, or just an accessory to do the lockout?
Posted : 12/03/2012 6:29 pm
Ho do i get the rose discount? Going to buy a pair if i cant find some 20mm maxle revalations...
Posted : 13/03/2012 8:53 am
peteimpreza - Member
"Biketown" is their retail store, there's a separate thingy for online availability
Posted : 13/03/2012 9:09 am
@SSBonty - the lockout/low speed compression adjust is on the top of the fork crown, you don't need the bar mounted lever (if they're the same as my Pike 409s).
Posted : 13/03/2012 9:14 am
Yup, the 409 has a steel steerer. Its seen as the cheapest hence the lower number. The higher the number the better the model (on pikes and argyles at least).
Posted : 13/03/2012 9:23 am
Find them on facebook, 'like' their page and you get a link to a EUR10 discount code for your first order.
Posted : 13/03/2012 9:29 am
Fuzzhead - sweet, thanks! Guess I can get a poplock later if I feel the need, never use it on my other forks though... These seem like great value for exactly what I need - I was looking for Sektors but pretty much no-one has the combination of 1 1/8 steerer and 20mm Maxle, certainly not anywhere near that price. They are obviously a lot heavier though! Ah well...
Posted : 13/03/2012 11:16 am
