Alfine help.
[Closed] Alfine help.
[#2061601]
Anybody managing to run an alfine hub where the Cassette Joint points inline with the seatstay?
I have looked on the instructions on Shimano Europe and I'm thinking you can't because you are limited by the orentations of the various no-turn washers.
Am I right or has anybody got a solution?
I have a frame wich has clips to run a full length of cable along the top tube and seat stay but I suspect it will only really work if I run the cable along the down tube and chainstay using Zip ties?
Thanks in advance.
Posted : 06/10/2010 2:17 pm
I ran mine with the cable along the top tube and down the seat stay then curved round to meet the hub down by the chain stay with no problems.
Posted : 06/10/2010 2:29 pm
Sounds interesting? Any chance you could post up a pic of that fella, coz I'm not quite with you?
Posted : 06/10/2010 2:32 pm
Vertical or horizontal dropouts - or angled? You should be able to find some combination of the washers that enable you to do this swapping them from one side to the other perhaps?
Posted : 06/10/2010 2:33 pm
Do you mean with a kind of "s" shaped kink in the outer so that it enters the Joint in the normal way?
Posted : 06/10/2010 2:35 pm
My plan is to put the 11 speed hub on a Yeti Big Top frame, but the horizontal dropouts aren't available yet. I was toying with the idea of running a tensioner for now with the vertical dropouts, but as I'm looking at the hub and the washers I've got I don't think it's going to work without looking a dog's dinner.I will have another look at it tonight, but I was wondering if anyone had managed the configuration already?
Posted : 06/10/2010 2:40 pm
redted - Member
I did that with a Nexus build (2003) before the Alfine.
[url= http://farm5.static.flickr.com/4110/5056731985_4d919c80b6_z.jpg [/img][/url][url= http://www.flickr.com/photos/34903211@N02/5056731985/ ]Instigator_Hub.JPG" target="_blank">http://farm5.static.flickr.com/4110/5056731985_4d919c80b6_z.jpg [/img][/url][url= http://www.flickr.com/photos/34903211@N02/5056731985/ ]Instigator_Hub.JPG"/> [/url] by [url= http://www.flickr.com/people/34903211@N02/ ]epicyclo[/url], on Flickr
Posted : 06/10/2010 3:18 pm
REdted - what would happen if you use the washers intended for angled dropouts? should be able to fiddle something with these I would have thought.
http://www.sheldonbrown.com/harris/shimano-nexus.html
Posted : 06/10/2010 3:25 pm
Cool thanks TJ!and for the pic Epicyclo. That's more variants of washer than I was aware of, should be able to do something with those. Forgot about Sheldonbrown!! V. useful.
Posted : 06/10/2010 3:47 pm
I ran it upwards deliberately. I didn't want anything down low where it could get hooked up.
(The bike was built up for an overland trip of around 1,300 miles in Oz . Riding conditions - open scrub on a compass bearing rather than a path)
Posted : 06/10/2010 5:06 pm
Yep grey on the left, black on the right. Works perfectly with a seatstay cable run.
Posted : 06/10/2010 5:19 pm
Brill, thanks Tony. I'll give it a go.
You've all been very helpful.
Posted : 07/10/2010 11:03 am
 Del
green and silver IIRC.
bent the cable stop out a bit to help clear the chain.
Posted : 07/10/2010 11:17 am
redted
what colour washers did you use green tab sprocket side and blue or silver the other?
Posted : 07/10/2010 12:38 pm
