Alfine 8
[Closed] Alfine 8
[#7300941]
Just noticed on my alfine 8, that there is independent movement between the hub and the disk, and a slight lose bearing feel on the rim.
Presumably something is coming lose. Anyone know what I should be looking at tightening?
Cheers,
Posted : 31/08/2015 1:01 pm
sounds like the disk lock ring is loose or the splines worn- get it nipped up quick - uses a cassette lock ring tool.
and your rim play sounds like the cones could do with a nip. Id suggest stripping and greasing the cup and cones while your at it.
Posted : 31/08/2015 1:09 pm
Would those two issues be related? Both the disk movement, and the rim play, started at the same time.
Posted : 31/08/2015 1:12 pm
