After ordering in J...
[Closed] After ordering in June 2015... Shockwiz content
My shockwiz boxes have finally arrived!
Just had a fondle of them out of the box, they seem pretty sturdy and solid feeling, downloaded the app and that seems fairly easy to use, though I haven't used it properly yet.
Can't wait to see what I'm missing in my suspension setup! Will report further after a proper ride
* yes I know it was a Kickstarter thing, rather than an order, but still.
Posted : 17/10/2016 11:55 am
 MSP
Interested to see what the results are, I am probably going to buy some myself.
Posted : 17/10/2016 12:03 pm
I was very tempted by this but got the sussmybike instead... Very interested in how you get on with it.
Posted : 17/10/2016 12:14 pm
 km79
I'd be gutted if the results were that I was already setup 100% no changes required!
Posted : 17/10/2016 12:21 pm
over-promise and under-deliver. it should be the kickstart motto.
i did look at them but then realised I'm actually really unfussy about my suspension setup.
Posted : 17/10/2016 12:24 pm
Really interested to hear about this and the podge's sussmyride too. If I had splashed the cash I think I'd have gone sussmyride just because interpreting pressure change using the shockwizz system sounds more difficult than the position indicator sussmyride are using. In both cases the hardware looks relatively simple but the software needs to be right
Posted : 17/10/2016 12:31 pm
The reason I went for the sussmybike is I was expecting to run a coil shock and the list of exclusions on the shockwiz is quite high even for air suspension.
I'm quite happy with my fork setup but no matter what I try I cant get the rear to feel anywhere near as good, figured that this would probably end up being cheaper than a constant swap of frames in search of the perfect one.
Posted : 17/10/2016 12:41 pm
Would like a go with them and thought about it when they were first announced. Thinking my group of riding buddies might want to buy a set amongst us all (6 regular riders) as it seems to be the sort of thing you'd use a few times a year not every day.
Posted : 17/10/2016 12:45 pm
 Leku
Tom - did you get hit with customs / VAT?
3 of us have clubbed together are are waiting for ours to arrive.
Posted : 17/10/2016 12:49 pm
Nope, the invoice says they are $0
Posted : 17/10/2016 1:14 pm
Hey Rubber Buccaneer,
ShockWiz looks at changes in pressure over time to map suspension movement and uses this information to to output very easy to understand recommendations. The amount of people that could constructively use the raw data is very low which is why it is hidden from the user. You install it, calibrate it, go ride, and then check the App to see how things look. The app recommends changes to your setup with very direct instruction such as; Add Air or Remove Air to adjust the air-spring pressure, Make Softer or Make Firmer for LSC and HSC, Speed Up or Slow Down for rebound, etc. An expert or a beginner should have no problem making use of the data.
Alex@Quarq
Posted : 19/10/2016 11:58 pm
Hey Leku,
Sounds like you may also be a backer, if not I figured I should still throw this in. Whether or not you get hit with customs or VAT depends where you live. The invoice that our system sends directly to the recipient does show a value of $0.00, because we are not actually charging the recipient when we enter the order. We are however legally required to include a commercial invoice with all international shipments. The commercial invoice must list a number of things, including an accurate device value. The value listed on the commercial invoice is $239.00 USD per ShockWiz unit, twice that if you ordered a pair. The recipient is then responsible for paying any and all duties and taxes.
Alex@Quarq
Posted : 20/10/2016 12:06 am
Hi Tom could I borrow it for the afternoon?
Hope it goes well please report back as I'm interested in these!
Posted : 20/10/2016 6:15 am
 Euro
Mama said say nothing if you've nothing nice to say... Fools! (Sang sweetly in a gospel choir stylee as to not offend).
Posted : 20/10/2016 6:58 am
Alex@Quarq, I like the idea, just waiting to see who does the best job of turning all that data into good advice for the user. It is almost a certainty that I will buy one of these systems when their availability and me having some money burning a hole in my pocket coincide
Posted : 20/10/2016 6:59 am
 Euro
Currently ill with the flu so read the user manual for this and i'm intrigued by this whole thing. It looks very impressive on the surface but lets say i fit it to my bike and ride down a trail. The info is gathered and the app suggests i make some adjustments.
Air pressure - add or remove some air
**Air spring ramp - remove or add spacers (tokens?)
Rebound - speed up or slow down
*HSC - softer or firmer
*LSC - softer or firmer
**Bottom out - add or remove resistance
All seems pretty straightforward on paper. However the ** requires proper tuning that's not that easy to do trailside or in the case of one of my set of forks the option * to adjust HSC/LSC or even +/- tokens isn't possible. So that's me goosed.
Someone with fancy Pikes (i have those too) might go home and add some tokens ready for the next 'test'. But it's rained heavily since the last one and the rider is going much slower. The suggested improvements don't seem to work and the new readings suggest making further alterations. An exercise in tail chasing ensues.
That's only one scenario - i can think of loads that sink this hi tech ship. I may be being overly negative but suspension is about feel (and compromise - no suspension works optimally everywhere), as feel gives confidence and that brings speed. An experienced rider should really know how they like the bike to behave and a novice probably has little use for this type of device. A shop could use it as a gimmick (like bike fit) to hook punters but unless this type of tech is linked to active suspension then it's just a gimmick. Like a balance band with a battery and a more impressive user manual. 😛
Happy to have my concerns addressed/bedunked by Alex since he's here.
Posted : 20/10/2016 9:35 am
I know when my suspension is working well, however I often don't know exactly what to change to hit that sweet spot from a new fork / shock out of the box. So it ends up being a lot of experimentation that could be shortcut with one of these. I really like the idea.
You can certainly fit a RS token trail side or back that trail head / by your car if you don't want to carry the tools.
Posted : 20/10/2016 9:47 am
 Leku
Ours has now arrived. No VAT or other charges payable.
Hoping to have a play with it tomorrow.
Posted : 20/10/2016 10:00 am
 Euro
So i have to buy a car as well as new forks? Could get expensive this 😀
Obviously joking and i get what you're saying for a brand new suspension unit. There is a bit of fiddling required but for me i a few clicks slower than middle for rebound is ballpark and usually only needs a click either way to be spot on (for feel). HSC/LSC i just go with what tuners suggest as i don't even notice it tbh (which is why i prefer basic forks over fancy ones). I also like my suspension firm so so does the app take that into account? It might tell me to back everything off, which my be optimal but not suited to how i like it.
Posted : 20/10/2016 10:01 am
Euro from memory of the original kickstarter vid you don't just ride down one trail and optimise for that trail surface and conditions
You ride your normal route which will cover different surfaces and conditions
The system looks at the overall shock / fork performance and recommends what could be improved in general
Obvioulsy if you only ride smooth trails and then ride go for a ride in a rock fest it ain't going to work
Posted : 20/10/2016 10:02 am
Euro - sounds like you know how you like your suspension set up, so a device to help you set up your suspension probably isn't for you?
Just a thought.
Si
Posted : 20/10/2016 10:13 am
 Euro
Yeah James, but some trails have smooth bits [i]and [/i]rock fests. Some have slow smooth bits and fast smooth bits - slow rock bits and fast rock bits. Slow drops and fast drops. Little jumps and big jumps. There's just too much going on imo for it to be of any real use to trail riding as it currently stands.
DH racing it may be slightly different as you are riding the same trail over the course of a weekend and can make adjustments after each run (and check the times to see if it actually helped).
Be interested to hear from the guys who have it to see what they think, or better yet, an independent review.
Posted : 20/10/2016 10:15 am
Euro, wouldn't you be interested to give it a go? Stick it on your bike and see if it suggested a change? Try the changes and test what they felt like? I would. Nothing like this is the be all and end all since personal preference and the confidence having things the way you like them gives can trump what should technically be an improvement. Bit like choosing tyres in that respect
Posted : 20/10/2016 10:31 am
 Euro
I would RB, if i though it would help and if i could rent one for say...£20.
The more i look at it the more questions i have though. Take my Xfusion rear shock. It's pretty basic but i like it. It does have 4 LSC settings which work pretty good. Which setting do i use when setting it up with this device? User manual didn't broach this that i could see. Fully open? Mostly closed? Somewhere in the middle? I currently have it set as best i can get it. It's a compromise of course but when fully open in rough stuff i blow the little rubber ring off the back on some bits of trail. Only solutions are add more air which will mess with how it works in the other settings that i'm happy with or send it off to a tuners which costs money. You can probably guess i don't like spending money if i can help it.
If Alex is reading this, send me one to test and if it works you can use me in your advertising bumf as the sceptic turned advocate 😀
Posted : 20/10/2016 10:46 am
If I could rent one for £20 I'd do it in a flash! I'm very sceptical that the data can be translated into sound advice for riders of all shapes and sizes on bikes and terrain of all types and even more so for a rear shock with endless different linkages but.....it's all just numbers, it could be done, maybe?
These devices could be excellent or could be a massive disappointment with endless software updates and a premature death. I don't know which it will be but I'm curious
Posted : 20/10/2016 11:02 am
I dont think it claims to give the ultimate tune, but give you better tuning.
I dont know how it works but I guess it must look at the data as a whole rather than an individual hit. That way it can identify that over successive quick impacts it was getting stuck too far into the travel (rebound too slow) or sitting to far into travel all the time (needs more air). While you might be able to discern this yourself there could be some extra tweaks you could make that you cant 'see' because you are too busy getting bucked about or dealing with line choice in a really bad section.
I guess it might be interesting to see if you could use it to get different settings for different stages in an enduro. Depends how much of the data it uses/needs to give an analysis though, if that worksyou could probably get it to give a good tune for car-park demos LOL!
Posted : 20/10/2016 11:14 am
Ours just arrived for the shop, we backed them out of curiosity and for something nice to play with.
One is coming home with me for 'testing', but the other is available to rent from us at Pedals in Edinburgh.
£50 for a weekend, or if you buy a bike/frame we might just let you borrow it for the setup free of charge, if you are nice.
Can't wait to see what it makes of my 120mm 3" tyred hardtail
Posted : 20/10/2016 2:04 pm
Hello Euro,
Debunk I will!
You are correct. For most, adjusting spring ramp (increasing or decreasing air volume) wouldn't fall into a 'normal' trail-side task. However, just because you can't do it quickly while sitting trail-side doesn't mean you shouldn't do it. I am going to make the very safe assumption that you work on your bike more off the trail than on, so that's not much of an argument. The device is designed to give you feedback that you can act on right then and there, or once you get home. If it requires tools you don't have with you, just do it later.
If your fork doesn't allow for tokens, then you can typically manipulate air volume by adding or removing oil to the positive air spring chamber. Certainly check with the manufacturer before you go doing this (doing this is friendlier to some air spring designs than others) but it accomplishes the same thing as a token, and people have been doing it for years.
If your fork doesn't have external LSC and HSC adjustments, that doesn't mean they cannot be changed. It does mean that it's harder, but it can still be done. This can all be addressed by manipulating the shim stack and oil weights within the damper. If this is above your ability, which for most it is, you can always employ the help of a professional. The point is ShockWiz provides you with the data to back whatever the change may be, which actually makes spending money on a professional that much more comforting. Or you can do as many will, and ignore the recommendations for adjustments you don't have knobs for. There is no harm in focusing on the adjustment you can easily change. In the end any adjustment in the right direction is going to help.
Changing conditions, along with loads of other things, will change the way you ride and the way your suspension should be set up. Conditions, terrain, skill level, etc; all play a roll. You need to remember though, that this exists whether you use ShockWiz or not. The fact that ShockWiz recommendations do change based on these factors only supports its effectiveness.
No matter how you set up suspension and no matter what tools or methods you use, there will always be a feel component. The problem is that feel is just that, feel. It's a person’s perception. There are some folks out there who can do this, but for every 1 that can, there are 10 that cannot. Companies wouldn't invest the amount of money that they do in education and the supporting material that go along with it, if this were not the case.
The adjustments on suspension products today all have a very wide range. This wide range exists because a single product has to work for a large variety of terrain, riding styles and ability levels, rider weight, etc. An unfortunate byproduct of this is that the majority of the available range is useless to any one person. You might have 15 clicks of whatever adjustment, but you should only ever live in a 3-5 click are of that. Setting it in the middle and going a few clicks up or down from there isn't going to cut it for the large majoirty. The hardest part of tuning for most is finding that sweet spot. It is so easy to end up outside it. ShockWiz works by helping find this, which ShockWiz inventor Nigel Wade affectionately calls the "Window of Happiness". When your suspension is adjusted within this window you have more control, which increases your confidence and allows you to ride faster.
In the end the goal of ShockWiz is to take the complicated, overwhelming subject that is suspension setup and make it easier. It's a device that fits easily to the majority of air sprung forks and shocks and uses live pressure data, sampled at 100x per second, to output easy to understand adjustment recommendations. I can promise you that it is no gimmick and I wouldn't be so quick to dismiss this type of technology. I would put money on this helping your setup.
If I missed anyone else's questions let me know, but I feel this covers a good bit of what others are asking/commenting.
-Alex@Quarq
Posted : 22/10/2016 12:29 am
 Euro
Hi Alex
Thanks for addressing some of my comments. I must apologise for applying the word gimmick to the ShockWiz as it's obviously a well thought out and polished product. I'm still not convinced of it's effectiveness in the real world, but as your chips are already damp with my urine, i'll refrain from posting why.
I wish you lads good luck
Marty
Posted : 22/10/2016 4:40 pm
 Leku
Just fitted ours to my rear shock ready for tomorrows ride. Fairly straight forward. Shame I won't be able to use it on my front forks as they are dual air.
Will report back tomorrow.
Posted : 22/10/2016 5:14 pm
Fitted mine to my fork ok, but I'm not sure I've done the shock right, it's a specialized/fox float with autosag, tried plugging it into the valve where I pump the air into the shock, nothing. plugged it into the red valve (that you use to let the air out to set the sag and it seems to work, though it's showing a red light in the cal status box (fork is green). Alex/quarq, is it calibrated?
Posted : 22/10/2016 9:34 pm
Tom you want it in the one where you pump air as the autosag one will not work when the shock is in use as that's in the negative air chamber once the plane stone passes over it.
Posted : 22/10/2016 9:53 pm
Doesn't seem to do anything when I plug it into that though, ie if I try and let any air out through the device, it doesn't do anything?
*rolls up sleeves and tries again
Posted : 22/10/2016 10:04 pm
Mmkay, tried again.
Readout is fluctuating between -15% and 15% of travel, and 202 and 203 psi, whilst stood still. Still red light on the cal status...
Ideas?
Posted : 22/10/2016 10:49 pm
I thought in the instructions it said it wouldn't work with brain shocks
Posted : 23/10/2016 8:27 am
 Leku
Just back from first ride.
[img][url= https://c7.staticflickr.com/6/5652/30392493742_4dd165e32d_k.jp g" target="_blank">https://c7.staticflickr.com/6/5652/30392493742_4dd165e32d_k.jp g"/> [/img][/url][url= https://flic.kr/p/NiFtwN ]ShockWiz[/url] by [url= https://www.flickr.com/photos/13146208@N08/ ]100%of thetime60%ofthetime[/url], on Flickr[/img]
Set up on starting;
[url= https://c5.staticflickr.com/6/5503/29878213484_57519c122e_b.jp g" target="_blank">https://c5.staticflickr.com/6/5503/29878213484_57519c122e_b.jp g"/> [/img][/url][url= https://flic.kr/p/MweDVN ]ShockWiz[/url] by [url= https://www.flickr.com/photos/13146208@N08/ ]100%of thetime60%ofthetime[/url], on Flickr
After ride (it tells you to do some rock garden, drops etc if those are missing from your ride so far)
[url= https://c5.staticflickr.com/6/5564/29878213724_70aa962f51_b.jp g" target="_blank">https://c5.staticflickr.com/6/5564/29878213724_70aa962f51_b.jp g"/> [/img][/url][url= https://flic.kr/p/MweDZW ]ShockWiz[/url] by [url= https://www.flickr.com/photos/13146208@N08/ ]100%of thetime60%ofthetime[/url], on Flickr
Suggestions;
[img][url= https://c1.staticflickr.com/6/5775/29878214264_43d3b309a6_b.jp g" target="_blank">https://c1.staticflickr.com/6/5775/29878214264_43d3b309a6_b.jp g"/> [/img][/url][url= https://flic.kr/p/MweEaf ]ShockWiz[/url] by [url= https://www.flickr.com/photos/13146208@N08/ ]100%of thetime60%ofthetime[/url], on Flickr[/img]
I knew the pressure was a bit down. Love seeing the 'real' pressure in stock after you have taken the pump off. As expected you do loss about 10psi. It suggested 200 psi is right for me (which is what I usually ride). 'Add spacers" - mmm I run a big volume Corset so spacers wouldn't make sense with that.
Will play with the big speed compression and bottom out (not elements I would normally know what to do with).
So far quite happy. More use for a new bike than one you've had for 5 years...
Posted : 23/10/2016 11:14 am
 Leku
One thing I didn't like is that you can't save the recommendations at the end of a ride. You have to do screen shots. Needs a 'save this ride' button.
Posted : 23/10/2016 11:17 am
Quarktech
Will this work on my DH 5 coil as it has the boost valve with schraeder valve for adjusting pressure?
Posted : 23/10/2016 11:39 am
Quarktech
Posted : 23/10/2016 11:40 am
So basically, you bolt that on, and it tells you everything you knew already?
For any given ride, just look at the O ring around the shock/fork piston, achieves exactly the same thing, costs way less....... 😉
I guess if you are a complete numpty, then it could help you get in the ball park faster for a new bike, but if you are that much of a numpty, then i bet you also aren't a good enough rider to actually notice or exploit any improvements?
Posted : 23/10/2016 11:50 am
 Leku
Max - I think there is a middle ground. I can sort sag and have a vague understanding of the other elements. It's nice to have a bit of kit which can make some suggestions based on the riding I actually do.
The fact that it got the recommended shock pressure spot on makes me think its a good bit of kit.
Posted : 23/10/2016 12:14 pm
Yes, it's a nice gimmicky thing that let's you pretend to be a suspension specialist for your very own race team.
I think Strava/power meters/Shockwiz etc. are the best bits about cycling for some people.
Posted : 23/10/2016 12:28 pm
Mines sat in a van somewhere got a 90squid import bill to settle first 🙂
Posted : 23/10/2016 12:33 pm
 Leku
It took 10 minutes last night to set up. It really didn't affect the distance or type of ride I was going to do.
Personally more time spent riding on a reasonably set up bike will make loads more difference to my skill/performance level.
Which is sort of the point of the ShockWiz..
This is the bit I took exception to. I accept I'm not that good at setting up bike suspension and this seems a good bit of kit [i]for me[/i].
Posted : 23/10/2016 12:54 pm
maxtorque - Member
Don't think this is at all true tbh. I can set up suspension without much fuss but nobody does it just by looking at the o-ring unless all they want to achieve is "make it work".
Which to be fair is what a lot of people think setting up suspension means.
Posted : 23/10/2016 1:09 pm
Max is awesome, not sure if I want to be him or marry him.
Posted : 23/10/2016 1:17 pm
Looking at those screenshots it is a royal waste of money. Seriously is that all it gives you in terms of info? Let's be honest max is pretty much bang on that an o-ring (plus a pressure gauge) will tell you 90% of that info.
Posted : 23/10/2016 3:00 pm
Reckon hanging off till the ios/android app thingy is developed to work off your phones accelerometer is the best option 😆
Posted : 23/10/2016 4:02 pm
Yeah, so now I've been able to set the sag and I know how much travel I used on a ride. It has little to tell me about what I may like to adjust, looks like shockwiz gives some recommendations. To me that sounds useful especially as my suspension adjustments are a laborious process of trial and error.
Posted : 23/10/2016 4:19 pm
On a closed course, data acquisition, in conjunction with segment timing makes sense. You look at your suspension dynamics, twiddle things, and find the setup that returns the fastest segment times. It's an iterative process.
However, just knowing what your suspension dynamics are doing, in isolation, is fairly pointless imo.
And as i said, if you really haven't got a clue, have no idea how to set say sag (even though to learn that you just need to RTFM andf look at the scale on the side of your shock these days) then perhaps shockwiz is for you? 😉
It's also the case than no single suspension setting can be optimum for every single different trail / useage, and for the rider who has no idea how to set their suspension and doesn't want to twiddle it every time they ride there bike, then they have to accept this compromise regardless.
Posted : 23/10/2016 5:42 pm
+1 well said that man.
Posted : 23/10/2016 6:42 pm
If you are racing and want every last fraction of a second you can get then I agree. But I don't feel that is a reason to dismiss these set up aids. I think they could be a useful aid to a lot of riders and I'd really like to give them a try
Posted : 23/10/2016 6:46 pm
Does anyone know how much these things are likely to cost once they go into production?
If you've got a few different bikes and different riders in your household / group, it might be a decent proposition. I'm certainly intrigued.
Posted : 23/10/2016 8:38 pm
 Leku
The app has 4 different riding styles - roughly XC, trail, trail plus & down hill. As you ride it highlights any types of riding not yet covered. This morning I used 'balanced' and I just had to add some drops on complete the session.
3 of us have clubbed together so a modest investment.
Posted : 23/10/2016 9:51 pm
Hey tomhoward,
Have you been able to sort the calibration issue out? Sounds like you were able to get the device properly installed on the positive air filler. Attaching to the Auto-Sag valve will certainly not work.
If the Shock Travel percentage in the App is not reporting properly then the CR has been incorrectly measured. You will need to complete the Calibration process again to correct this. I also recommend that you watch the "Calibration and App Setup" video found on [url= http://www.shockwiz.com ]ShockWiz.com[/url]
Duirng the calbration process it is important that before you perform any of the Full Extension or Full Compression measurements that; 1) you have enough air removed that you will be able to fully compress the shock, 2) and that you have properly balanced any remaining air the positive and negative air chambers by cycling the suspension after you have deflated it.
Another thing to note is that when making these measurements do not have the ShockWiz inflation valve depressed. ShockWiz must be able to measure the pressure change from Full Extension to Full Compression in order to measure the compression ratio. Depressing the valve will make for easy compression, but it means the pressure inside the positive air chamber won't increase and ShockWiz will be unable to make the necessary measurements.
Alex@Quarq
Posted : 11/11/2016 1:01 am
Hey Leku,
I am surprised that the [b]removal [/b]of the shock pump is causing the pressure to decrease. The only time a shock pump should affect the positive air spring pressure is during pump installation, as pressure from the positive air chamber escapes from the shock/fork to charge the pump. The Schrader valve of a shock, fork or ShockWiz, should be long closed before the seal between the pump and the inflation stem breaks free and you hear a hiss of air.
Either way, looking at your screen shots I would suggest you make sure your Shock Travel percentage is at 0, +/-3%, at the start of your ride. I am not sure if you were sitting atop your bike when you took those screen shots, but 7% is quite large. This could be negatively affecting your readings. To zero the Shock Travel re-set the baseline air pressure with the bike unweighted. It is good practice to lift the wheel off the ground when doing this to insure you get a truly unweighted measurement. Baseline Air Pressure can be reset from the settings page of the app, or by selecting the "Shock Travel" value on the home page.
It is also very important when making adjustments that you do so in a prescribed order. If you have recommendations for Baseline Pressure and Ramp they should always be done first (when applicable) as these are more or less your foundation to work from. Once you get those sorted you can then move down the list into the damping adjustments. We have a brief article regarding this on our website [url= https://www.shockwiz.com/2016/09/30/suspension-tuning-order/ ]here.[/url]
The "Save" feature has been suggested quite a lot, and we intend to provide this in some way or another. The only thing to consider with this working is it means you're going to have to start counting clicks and manually entering data. The Suggestions made by the app are made without ShockWiz knowing anything about where your damper settings are. Without tracking your damper setting the saved screen shots of Suggestions will be of little value once you start changing things.
The better thing to do, at least in the short term, is to focus on getting your suspension feeling as good as it can for the given terrain/area, to where both you and ShockWiz are happy. Once you get to that point then record all the settings you have and tuck that data away for when it's needed. Repeat this process for any trails/areas/events in which you want a specific tune. This way you can apply those settings when they're needed.
Also, ShockWiz stores everything device side, not app side. The app is merely a means of viewing the data, calibrating the device and selecting "New Session". You can always connect back to the device after the ride to see the data if you prefer that over screen shots. It is not until you select "Start New Session" that the ride data will be deleted.
Alex@Quarq
Posted : 11/11/2016 1:32 am
Hello cyclelife,
Unfortunately ShockWiz does not work when connected to the IFP chamber, which is what you are describing. It has been discussed whether or not this could work, it has just not yet been explored.
Alex@Quarq
Posted : 11/11/2016 1:48 am
For some reason mine does not like to wake up, has anyone else had any issues?. I managed to start it up by removing and re-installing the battery?
Posted : 12/11/2016 6:06 pm
This is something myself and my mates have been interested in for a while. Every shop bumps you off saying it's 'rider preference'.
I'm interested to hear how the device understands when the fork/shock is in firm for climbing, trail mode or DH mode? How does this effect the readings/results?
Posted : 12/11/2016 10:46 pm
Rick Draper - Member
Hey Rick,
Is the device mounted to a fork when it is difficult to wake? Or is it just as difficult on a rear shock?
Removing and installing the battery will often get a device to wake, but it certainly shouldn't be a normal procedure. It can also cause the accelerometer to go into a weird state where it makes it even more difficult to wake, or it won't wake at all.
So...here is what you should do.
Perform a reboot on ShockWiz by shorting the battery contacts of the device. The easiest way to do this is to install the battery into the battery tray upside down for a few seconds(positive side of battery facing the circuit board). Then remove and install correctly (positive side of battery facing away from the circuit board.
Then let it go to sleep (10 minutes of inactivity) and see if it now wakes easier.
If it does not, then you need to get a bit more aggressive. You should be able to just lift the wheel off the ground and give it a drop 3+ times. This is often sufficient.
If not, step it up a notch by lifting the wheel off the ground and this time giving it a bit of a slam.
Let me know if this helps.
-Alex@Quarq
Posted : 14/11/2016 9:01 pm
To All,
Here is some overall useful information regarding how ShockWiz works, as it pertains to data storage, data transmission etc.
-Alex@Quarq
[b]Data storage:[/b] All data collection and analysis is performed within the ShockWiz device itself; no computation occurs within the app. The app is only a means to display the collected information and for you, the user, to interact with the device to perform a task such as a calibration or to start a new session. Since the data is stored directly on the ShockWiz device it is not necessary to carry your phone during a ride. However, once you have the ShockWiz app open and connected to your device you can check the results at any time. This could be at the end of a segment, the end of a ride or in three weeks time, it doesn’t matter. Your data will be saved until a new session is started.
[b]Using two devices:[/b] If you have a dual suspension bike, then it is beneficial, but not essential, to use two ShockWiz devices simultaneously. The process of using two devices is very similar to using one. You simply have to connect to each device individually to set them up and review the results. To switch between devices, simply tap the device name at the top of the app page and select your other device from the list. On some phones it may be beneficial to first disconnect from the current device before you connect to the other.
There is no communication between ShockWiz devices, only from each device to the phone/App. Tuning, however, does become much faster with two devices because you are capturing twice the data at once and there is no need to swap from the front to the rear. Typically, but not always, both the front and rear of a dual suspension bike should be set up and tuned with the same Tuning Style.
[b]Tuning Styles[/b]
When it comes to tuning mountain bike suspension, there is a lot of variance in how people like to ride and the different styles of bikes for different terrain and disciplines. The Tuning Styles within the ShockWiz algorithms try to account for these variances.
Some people like to use every last millimetre of travel, while others like to have a large travel buffer in reserve for any unforseen obstacles. Additionally some riders like to have the bike be lively underneath them and be able to ‘pop’ off small mounds and kickers, where others like the wheels to be very planted to the ground and controlled.
There are quite a few things that change between Tuning Styles, but the following descriptions give an overview of the main differences.
[b]Efficient [/b]- Focused purely on pedalling efficiency. Efficient will keep you higher in your travel and minimise pedal-induced suspension bob. Efficient produces the firmest suspension tune.
[b]Balanced[/b] - The middle ground that provides an overall compromise between traction, suppleness and pedalling efficiency. Balanced serves as the default ShockWiz Tuning Style.
[b]Playful[/b] - Similar to Balanced but with a more lively feel to give the bike ‘pop’.
[b]Aggressive[/b] - Focused on a supple and active ride, caring very little about pedal-induced suspension bob. Aggressive makes sure you use all of your travel and produces the softest suspension tune.
Posted : 14/11/2016 9:05 pm
Guys, you have all had this a few weeks now so I am interested in your feedback on the results before I go hire one?
What's your initial thoughts on the results? Is this something that takes a day to set up or is it very much still 'work in progress'?
Thanks.
Posted : 04/12/2016 7:43 am
Now available to the rabble, at £359rrp (group buys make sense)
So how have the backers gotten on with theirs? (as per legendof1973)
Posted : 15/02/2017 5:52 pm
£360 quid!!! yikes thats expensive. Might be a good purchase for a bike shop but as an individual its not something i'd consider
Then again, i'm not sure i'd ever notice the difference even if i had one, i leave all my suspension settings well alone.
Posted : 15/02/2017 6:41 pm
