advice wanted re-ad...
[Closed] advice wanted re-adding gears to an old single speed mtb
[#5893980]
I am convervting my old Orange Evo back to a geared bike - rear only - and was wanting to see if anyone had any advice on whether I will need to use a chain device to maintain tension as I am only using a single ring up front. I am using an old ish road cassette and chain to keep the gear ratios on the quicker side with the old middle ring on the front.
I have a square taper BB and as the bike will only be occaisional use dont want to sepnd much....so dont want to have to change much to use a tensioner.
Any thoughts on whether this should work ok?
Posted : 26/01/2014 8:50 pm
Your rear mech will sort tension.
You'll need a top-only style device up front to stop the chain coming off.
Posted : 26/01/2014 8:52 pm
The derailleur will act as a tensioner for the gears but unless you use a chain device or thick /thin chainring you may suffer from chain drop at the front.
Posted : 26/01/2014 8:53 pm
Any recommendations for chain tensioners?
Posted : 26/01/2014 9:39 pm
or device up front
Posted : 26/01/2014 9:48 pm
the Superstar top only guides ones will probably be enough.
Posted : 27/01/2014 8:33 am
Try it without first, when I've run 1xwhatever gearing I have never used a chain guide.
APF
Posted : 27/01/2014 9:04 am
