this may be a idiot question but here goes.
can i use a 160mm formula oro k18 rotor with this hayes stroker brake unit?
http://www.merlincycles.co.uk/Bike+Shop/MTB++Parts/Brakes/Disc+Brakes/Hayes+Disc+Brakes/Hayes+Stroker+Ryde+Rear+-+No+Disc_HAYESSTROKERREAR.htm
if so will the stroker caliper fit on to the fork or will I need a adapter?
thanks DTD
pretty please ! 😆 😆 😆 😆 😆
Its a standard post mount caliper so as long as you have the right adapter or fork mount then it will be fine. What fork is it? What mount does it have?
sorry its a rear is mount so im hoping the formula 16omm mount will fit the hayes stroker
If it's rear you'll almost certainly need an adaptor, very few frames are Post Mount. You'll need disc adaptor for 160 rear, PM calliper to IS frame.
APF
thank you
