Adhesive for innert...
[Closed] Adhesive for innertubes
 JoeG
I've run the wheels on my regular bike tubeless for many years with Stan's rim strips (the rubber ones) and sealant. Now that I've got a fatbike, I'm trying to go tubeless on that one as well. I have successfully converted one wheel to tubeless using Gorilla tape, but I really wonder whether it will last long term.
So, I am trying to widen a Stan's rim strip. I have cut one in half, and tried to glue it to a split 20" innertube. So 1/2 of each rim strip is at the rim's bead seat, with the split tube in the middle.
But I need to find a good glue to use. I bought a can of rubber cement as used with tire and inntertube patches and it is worthless; it peels right apart. I had some Permatex Black Rubber Sealant that was definitely stronger, but it let go in 2 places when I rode the wheel yesterday.
So, does anyone have an suggestions for what to use to glue my split tube and rubber rim strips together with>
Posted : 28/01/2013 6:09 pm
Sanded both down first? tried vulcanising solution?
Posted : 28/01/2013 6:20 pm
Try that 3m cross weave tape - it comes wide enough so you won't have to join.
Posted : 28/01/2013 6:22 pm
 JoeG
What is vulcanizing solution?
Went to various auto parts and a farm store that had tire patches and such. They all had rubber cement that was basically the same as what I bought.
Posted : 28/01/2013 8:16 pm
