Adding a granny rin...
[Closed] Adding a granny ring to a 1x
[#5215200]
Morning All,
Currently running a Hope 32 tooth front ring and looking at fitting a standard granny ring to make it a 2x for a trip. Am I going to have issues shifting up onto the Hope ring as it doesn't have the little ramp/pick up pins or a bit of plastic a'la Shimano xt M770?
Got all the other bits but dawned on me this might be a problem
Posted : 04/06/2013 7:21 am
You might have a problem as in it won't shift well due to the no pick up pins, but it should work of a fashion as back in the day there were no pick up ramps and bits to aid it, and they still worked, kinda of.
Posted : 04/06/2013 7:24 am
Chainrings were all like that once upon a time.
More likely to have 'issues' shifting off it than onto it. Just be smooth about your shifts and try not to load the chain while you're doing it. May need a bit more planning on ascents than you're used to if you've only ever used ramped & pinned rings.
Posted : 04/06/2013 8:29 am
Cheers Guys,
I'm pretty slick and thoughtful on the shifting and no probs in setting it up correctly either.
Suppose it boils down to is it worth spending the ££ on a new middle ring for a 5 day trip, or make do and be gentle.
Posted : 04/06/2013 9:33 am
