Pretty sure the answer is no... There's a set of 29er rebas on sale locally with bad stanchions, I have a set of 26er Revs with good stanchions, what are the odds that one will go into the other. None?
google part numbers?
Although the likelihood of them been even the same year/type is probably pretty remote.
Your intuition is correct. No, they're different parts.
TBH I was under the impression only the lowers changed. My 29er Reba's lowers look to be extended, the lower nuts/adjuster is quite sunken into the leg.
The 29er lowers always looked like the same to me, but with the big hollow extension at the bottom. I'd be surprised if a 26er Reba with 29er lowers didn't work.
Revelation stnachions are probably longer than reba ones though
