A question about ca...
[Closed] A question about carbon rims and punctures.
[#7313948]
I've recently converted to carbon rims and I seem to be having a lot more flats than normal.
Its an xc race bike so very stiff and light, I used to run Mavic crossmax SLR's and didn't have much problem with flats and I would consider this a stiff wheel. Is there a common problem with stiff (carbon wheels) and punctures?
I've run Stans Crests with no problems either.
I have had the problem with tubeless and as well as with tubes.
Is this common?
Posted : 07/09/2015 11:06 am
what sort of punctures - snakebites?
Posted : 07/09/2015 11:07 am
I think so.
Posted : 07/09/2015 11:08 am
Can't say I noticed any difference. Stans are sometimes said to be a bit better with pinchflats because they're pretty soft and round- basically the easier it is to deform the rim the harder it is to pinch, but that's got it's own disadvantages... I wouldn't think the same applies to the mavics though?
Rim shape could play a part but my LB rims have pretty rounded edges
Posted : 07/09/2015 11:10 am
I presume you are running them with tubes. Why not give tubeless a go?
Posted : 07/09/2015 11:12 am
I run them tubeless, then punctures when I was out and about and then put a tube in to get home. I left the tube in for a few days and then punctures that before I set up the tubeless again.
Posted : 07/09/2015 12:33 pm
