After a cheap one that you manually pump to keep in the boot for getting worst of the cack of the bike - anyone got one they can recommend?
PS. not looking for a Mobi equivalent, just something simple 🙂
Got a Nomad - bit pricey but good. I use it at home instead of a high pressure hose as well. Bought it as a 'hose pipe ban beater' works well.
Wilkinson trip in order my friend....
DrP
I tried a caravan water pump, fitted a bit of hose and a hose gun. Wasn't brilliant but sort of worked. Oh and you will need a 10 or 25 lt drum.
I recommended (and still do) this one, although STW forumers didn't seem to like it, probably because it's only £7.50!.
Does the job for me, sprays off most kack, if I want a thorough clean I wouldn't use a higher powered jet washer anyway, I'd do it by hand.
[url= http://singletrackworld.com/forum/topic/psa-pressure-water-cleaner-for-750 ]Wilkinsons weed killer sprayer[/url]
I've got an Asda plant sprayer, about 2.5l, just about enough to get the worst of the muck off your bike before you throw it into your expensive Audi............. (cost a wacking £3.25 as well 😉
motivforz - link doesn't work but I suspect its what I'm after. As you say its only to get the worst off before loading it in the car - I'll give it a proper wash back home.
I got one of these, for less than £25 though I think:
Does what you'd expect reasonably well, i.e. you can spray off the worst of the loose / wet dirt before you put your bike back in your car. A spray with Muc-off or similar first would probably help. If you're quick, you can get most of the mud off two bikes with one 'tankful'.
I just use a 5L manual garden weed sprayer thingy (have to pump it by hand...ooooeeeerrr) from Homebase i think...didnt cost much at all and gets most of the heavy stuff off before it goes in the car for the journey home.
I use an 18v Nomad, great bit of kit and very much worth the money, I also use it with a garden sprayer with sh*t shifter in for a quick clean wash usually in the dark
I know it's not what you are looking for but crc have 33% off the mobi at the moment. I bought one today.
I got a mobi v15 for Christmas last year and it has been great for cleaning my bike, i'm in a flat with no outside tap so it i use it for cleaning the bike at the trail then just turf it in the shed when I get home.
Another Mobi user here (V17), had a Mobi version which lasted a year before the power connections corroded, and replaced with a Clas Ohlson version, which is the V17 with a green reservoir as opposed to the blue of the Mobi, it also has a better spray gun, and warranty, and is a lot cheaper when they have it on promo every couple of months (paid £39.99).
Yep, big volume Weed sprayer from any hardware/garden store.
Not perfect or super powerful, but on cost Vs performance it's a winner.
that go outdoors one looks like a decent bit of kit. friend of mine uses a hand pumped fence sprayer, it's not as good as my mobi but does the job. I got my mobi when they were on offer at £50 and it's one of the best bike related things I've bought.
