im after some rigid forks to replace my 130mm recons on my sanderson been riding with them locked out for the last 7-8 rides and it tracks/rides so much better i can only find 26" spec forks up to 120mm
idealy carbon but any help is better than nothing
thanks.
Mine are 470mm if that helps
and both are mine are (niner forks)
470mm on the On-One carbon fork
I've bought 2 pairs for Scandal 29er and experimenting with 69er Genesis Altitude:
eXotic Carbon Rigid CC-F0365 29er fork - same as White Brothers - 465mm
Salsa CroMoto 29 Inch Forks - 468mm
Both are supposedly suspension corrected for 120 travel, after sag has been taken into account.
Here, a list of a few susp. fork a-c - maybe it helps..
FOX
All models +/- 5mm
F80: 450.9mm
F90: 460.9mm
F100: 470.9mm
F120: 490.9mm
Float, Talas, Van 130: 500.9mm
Float, Talas, Van 140: 510.9mm (08 Talas: 515mm)
Talas 150: 520.9mm
Float, Talas, Van 160: 545.3mm
Fox 40 180: 545.8mm
Fox 40 203: 571.2mm
ROCKSHOX
All models +/- 5mm
99-08 SID 63: 434mm
99-08 SID 80: 451mm
Argyle 80: 471mm
Argyle 100: 491mm
SID 80: 453mm
SID 90: 463
SID 100: 473
Dart 80:454mm
Dart 100: 471mm
Dart 120: 501mm
Tora XC/SL/RACE 80: 450mm
Tora XC/SL/RACE 100: 470mm
Tora AM 80: 459mm
Tora AM 100: 479mm
Tora AM 120: 499mm
Tora AM 130: 509mm
Recon XC/SL/RACE 80: 451mm
Recon XC/SL/RACE 100: 471mm
Recon AM 80: 459mm
Recon AM 100: 479mm
Recon AM 120: 499mm
Recon AM 130: 509mm
05-08 Reba 85: 458mm
05-08 Reba 100: 473mm
05-08 Reba 115: 488mm
Reba 80: 453mm
Reba 100: 473mm
Reba 120: 493mm
06-08 Revelation 100: 478mm
06-08 Revelation 115: 493mm
06-08 Revelation 130: 508m
Revelation 140: 521mm
Revelation 140 w/Maxle Lite: 518mm
Pike 95: 473mm
Pike 140: 518mm
Boxxer Ride 130: 494mm
Boxxer & Ride 174: 544mm
Boxxer 200: 568mm
Domain 115: 500mm
Domain 160: 545mm
Domain 180: 565mm
Lyrik 115: 500mm
Lyrik 160: 545mm
Totem 135: 530mm
Totem 180: 565mm
oops...that's a long post!
forgot to say, I have a Rockshox Reba sl 29er fork which has 80mm travel, and a-c is 490, same as 120mm 26er forks.
The exotic website has full a-c details for all their forks. I used a set of their 29er forks on my Soul to keep a 130mm-ish feel to the bike, very nice. It's really obvious but do bear in mind that full a-c length on suspension forks is pretty meaningless, it's the sagged number that's relevant.
thats true but is not the sag length calculated at 20-25% of full length:
I also have an old frame with 100 susp. fork - and it was good to know actual length of that fork to know, after sag, roughly what rigid fork length I needed to keep geometry intact.
i run bairly any sag due to the way i ride as need a stiff front end that would give under hard landings (hold the funny comments lol) but after riding locked out i realased i dont need the give and land smoother than i thought(prob as used to racing bmx)
rp16v - from that list I found and posted earlier, the Recon AM 130 has a-c 509mm- to keep the geometry intact will you not need a similar length fork?
correct but i as mine is a older fork and think it may be slightley shorter a-c and all 26" forks are way short so testing the 29er water.
might well plump for the 29er exotics as sugested.
currymad - Member
"thats true but is not the sag length calculated at 20-25% of full length:"
Well, of the travel rather than the full length (and depends how much sag you use, as rp16v points out)
yes, well clarified, I meant full length of travel.
That's what I meant though with no sag, he will need a similar length to his existing forks a-c...I think!
As you said Northwind: It's really obvious but do bear in mind that full a-c length on suspension forks is pretty meaningless, it's the sagged number that's relevant.
In his case the sagged (or not) length is the same as full a-c.
iv managed to get some 29er forks of a diamond back mojito to try so will bolt them on and take som epicks when i get a chance.
