A 1x9 aesthetics qu...
[Closed] A 1x9 aesthetics question
[#2807034]
When you convert regular 3 chainring cranks to 1x9, does the single 'middle sized' chainring have to go on the inside of the crank bolts? It seems to me as though this could look a bit wrong with the outer ring missing. Or is that just too fussy? Maybe I haven't explained this well.
Posted : 31/05/2011 6:40 pm
 gee
Hi
Yes - it has to go on the inside of the spider in the middle ring position. It doesn't look that silly.
GB
Posted : 31/05/2011 6:43 pm
Guess that, whether you need one or not, aesthetics may make a reason for fitting a bash?
Posted : 31/05/2011 6:51 pm
Single rings look much better with a bash unless you get a pimp cnc'd ring
Posted : 31/05/2011 6:54 pm
Do bash guards and chain guides usually fit ok together? The bash guard doesn't foul the chain guide? Suppose it depends which one(s).
Posted : 31/05/2011 7:50 pm
 gee
Don't bother with a bash guard - just extra weight...
GB
Posted : 31/05/2011 7:58 pm
As Gee says, bash gaurds can add significant weight - you'd really notice [url= http://www.bbgbashguard.com/Mountainbike.html ]all of 50g mounted centrally![/url]
8)
Posted : 31/05/2011 8:04 pm
Looks fine to me:
Posted : 31/05/2011 8:10 pm
I've used a dangerboy bash and modified an e13 guide like the one on sammyCs above. I don't use the roller or the 'skid' that's part of the e13 setup, no need to functionally and was having bearing issues on the roller jockey. Oh and it's a 1x9 setup. Never lose a chain and offers good protection. Looks? Yeah looks ok and not bothered about the weight, the positives are worth it.
Posted : 31/05/2011 8:46 pm
Leaving it in the 'middle' position will typically give you a better chain line. If you are using a std middle ring it will probably have the bolt holes counter sunk so the bolt fits better when fitted behind the spider.
Posted : 31/05/2011 8:55 pm
I have a stainless On One SS ring fitted in the middle position on one bike and just gone 2x9 on the other by removing my large ring and the only niggle I have is the recesses in the spider where the large ring goes. I am going to make some carbon fibre fillers to sit in there and save me buying a new set of shorter chainring bolt.
I am not a fan of bash guards. I have an aluminium race face one that looks better than the plastic Shimano ones but I wouldn't run one in 3x9 and I now have more clearance so should be fine.
Posted : 31/05/2011 10:13 pm
better having a guide to stop the chain falling off than a bash. imo.
Posted : 31/05/2011 10:15 pm
The Pauls chain guide is probably the neatest one I've seen, certainly the smallest. A lot of them are quite big aren't they.
Posted : 31/05/2011 10:17 pm
Yeah I have pauls and it works pretty well and is easier to allign with different axle lengths, I want the new hope one though
Posted : 31/05/2011 10:23 pm
It's been said a number of times, but BBG + N-Stop = Win
Posted : 31/05/2011 10:33 pm
I just cut and filed teeth off the old big ring when I set up SS. Looks 'normal', no cost, acts as guide and bash.
Posted : 01/06/2011 6:52 am
I have always used a BBG + N-Stop, I haven't had a triple for almost 3 years and don't miss it, currently in the process of converting my Cotic X to 1x9.
Posted : 01/06/2011 7:54 am
middle
[url= http://farm5.static.flickr.com/4107/5063008616_da86514d39_z.jp g" target="_blank">http://farm5.static.flickr.com/4107/5063008616_da86514d39_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/rocketdog/5063008616/ ]Renthal + N-Stop[/url] by [url= http://www.flickr.com/people/rocketdog/ ]rOcKeTdOgUk[/url], on Flickr
Posted : 01/06/2011 8:01 am
Is that on a 1x9 rocketdog? Surprised the chain stays on with only one side of the chain being guided.
Posted : 01/06/2011 2:14 pm
